- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyCLOUD not connecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to connect via readycloud. Says nas is off line which it isnt
any solution ?
Cheers
bill
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyCLOUD not connecting
What firmware are you running on the ReadyNAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello mc41,
Are you logging in via ReadyCloud portal? Please let us know the current firmware version.
Also, please see if you are using the same account that is shown as "signed in as" on the admin page's Cloud > ReadyCloud.
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello mc41,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello mc41,
Please provide more info.
- What is the model number of the NAS?
- What is the current firmware version?
- Are you logging in using the main ReadyCloud account?
- Is the ReadyNAS getting on the Internet?
- Are you using a computer that is connected to the same network where the NAS is when logging in to ReadyCloud portal?
- When you use ReadyCloud app on Windows/Mac desktop or on an Android, do you get the same problem?
- Do you log in using ReadyCloud account that is in an email address format?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Readynas 104
serial 3EPE4CEH00DF2
firmware 6.6.1
log in on mac desktop using RAIDar no problem,the readycloud sitting ontop screen in tool bar section, just spinning saying connecting (which it never stops tying to do and never connects
Are you logging in using the main ReadyCloud account? ??? Not sure what you mean
Is the ReadyNAS getting on the Internet? ???? not sure what yiou mean
Are you using a computer that is connected to the same network where the NAS is when logging in to ReadyCloud portal? (cant log onto portal)
When you use ReadyCloud app on Windows/Mac desktop or on an Android, do you get the same problem? yes
Do you log in using ReadyCloud account that is in an email address format? the user name on the computor toolbar is not a email setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Look in the admin web ui and see if you see "internet available" with a green checkbox in front of it on the cloud page.
Did you set up a readycloud account on the portal? ReadyCloud accounts are managed by Netgear, and they all are in email-address format.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might try adding 8.8.8.8 as a ReadyNAS DNS server. That's google's open DNS server.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem... with DNS 8.8.8.8
can you help me?
- Mark as New
- Bookmark
- Subscribe
- Permalink
can you help me?
Does the cloud page show a good internet connection?
If not, are you using a static IP address?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The internet connection is very good. I use a static IP.
It affects all Windows client. IOS Mobile Client works fine...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Perhaps you misunderstood. I wasn't asking if your internet connection itself was good. I was asking if the cloud page on the admin web ui showed a status of internet connected with a check mark in front of it.
The most common cause of your problem is a misconfigured static address. Leaving out the DNS service is very common, though that doesn't seem to be your problem. You might also add your ISPs DNS service(s) to the configuration on the NAS. A misconfigured subnet mask or gateway address can also cause your problem.
Also, what firmware is your NAS running?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware 6.6.1
Windows Client 1.7.6.28
The system ran smoothly until yesterday
- Mark as New
- Bookmark
- Subscribe
- Permalink
@phsandmeier wrote:
Firmware 6.6.1
Thanks.
So the ReadyNAS thinks it is connected to ReadyCloud. The next step is to see if ReadyCloud agrees. Log into the ReadyCloud web portal to see (don't use the client).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the web portal also connects to your NAS, then the problem has to be with the client software
Try them again first (since ReadyCloud does go down from time to time).
- Mark as New
- Bookmark
- Subscribe
- Permalink
On my Ipad works the client fine. It only not works on windows
I need the service for work. it is scary... downtime 24 houre and more!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe try uninstalling/reinstalling the windows client.
There are other options that you might find more reliable (or that you can use as backup methods).
If your company has a VPN deployed, you might be able to access the NAS directly when you are using their VPN.
Other alternatives include owncloud (you can get a good app for that from https://rnxtras.com/) and ZeroTier. There's a thread on ZeroTier here: https://community.netgear.com/t5/Using-your-ReadyNAS/ZeroTier-and-the-ReadyNAS/m-p/1163028#M118703
