Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
* ReadyDLNA Update Addons [Updated: 2014/11/13]
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-04-16
04:27 PM
2009-04-16
04:27 PM
Sparc (Duo/NV/NV+/1100/X6):
x86 (Pro/NVX/Ultra/Ultra Plus):
ARM (Duo v2/NV+ v2):
Last update: 2012/04/04
Requirements: Must be running RAIDiator 4.1.6+ (Sparc), 4.2.16+ (x86), or 5.3.3 (ARM)
Installation:
Changes:
Installation:
- 4.x: Install in Frontview under the System->Update->Local Update tab.
- 5.x: Install in Dashboard, click Configure, go to the Add-ons tab, click the + button at the far right.
Changes:
- 2014/11/13 [1.1.4]
- Add Asus O!Play client support.
- Fix crash bug with an emtpy filter argument.
- Accept SMI subtitles in addition to SRT.
- Add BubbleUPnP detection and enable subtitle support.
- Disable Samsung DCM10 capability, as it breaks compatibility with new models.
- Add subtitle support for NetFront™ Living Connect middleware-based clients.
- Add magic containers for 50 recent items for each category.
- Fix bad null termination in AAC parsing.
- Fix requests for the last byte of a file, which affected MKV playback on Philips TV's.
- 2014/04/29 [1.1.2.3]
- Fix multicast issue.
- 2014/04/16 [1.1.2.2]
- Fix a couple resource leaks.
- Support DLNA/UPnP-AV searches issued by clients using the Grilo framework.
- Fix some clients playing artwork instead of movie.
- Fix bookmarks on Samsung Series E clients.
- Add an extra folder level if there are multiple media locations.
- Fix some multicast membership issues with changing network settings.
- Fix choppy playback with some file types on Panasonic clients by increasing the max connection limit.
- 2014/01/16 [1.1.1.2]
- Add support for TiVo MPEG-TS files.
- Add forced sorting support for some Panasonic devices.
- Fix some minor spec compliance issues.
- Fix some resource leaks.
- Add a new force_sort_criteria manual config option, to globally override the SortCriteria value sent by the client.
- Fix issues with deleting entire folder contents, and then re-adding content back to the same folder. This can cause '(null)' folder names.
- Update NETGEAR icon images to match the new branding.
- Add a primitive presentation page (http://ip:8200/status/) to show client status and library counters.
- 2013/03/07 [1.1.0~rc4]
- Fix crash caused by certain TiVo clients.
- Fix crash bug on certain types of video files.
- 2012/07/13 [1.0.25]
- Add DirecTV client detection, and fix image resolution issue.
- Make DeviceID checking more permissive for Sagem Radio (and maybe others).
- Enable all network interfaces by default.
- 2012/04/04 [1.0.24.3]
- Fix a scanner crash on certain malformed WAV files.
- Fix discovery problems with Xbox 360.
- 2012/02/16 [1.0.24]
- Enable the subtitle menu on some Samsung TV's.
- Add subtitle support for Panasonic TV's.
- Speed up playlist parsing.
- Make metadata-based virtual containers case insensitive.
- Add folder art support (very few clients support this though).
- Fix SRT caption support with the latest Samsung Series D firmware.
- Fix subtitles on LG TV's for items whose titles don't have a dot in them.
- Add support for the av:mediaClass tag, so some Sony devices can filter items by media type.
- Fix automatic change detection on first-level folders.
- Work around LifeTab's broken DLNA support.
- Add image rotation support during resize. (mostly useful for TiVo)
- Add bookmark support for some Samsung TV's.
- Add WAV file support for Marantz Receivers and Roku SoundBridge.
- 2011/07/18 [1.0.21]
- Fix FF/REW of AVI files on Samsung Series B TV's.
- Fix a crash bug when playing music on TiVo.
- Add WAV/RIFF INFO tag parsing support for the most common tags.
- Fix a crash bug with clients that request a large number of results (i.e. Xbox 360).
- 2011/06/10 [1.0.20]
- Improve support for the NETGEAR Digital Entertainer Live (EVA2000).
- Fix a crash bug when scanning MPEG-TS files with odd packet sizes.
- Work around Samsung A-Series TV issues with AVI file streaming.
- 2011/05/17 [1.0.19.3]
- Add support for external subtitles on LG TVs and Blu-ray players.
- 2011/05/16 [1.0.19.2]
- Fix a possible crash with clients that didn't include all the normal HTTP headers in their network discovery packets.
- 2010/03/19 [1.0.17] [Included in RAIDiator 4.2.9]
- Add m3u and pls music playlist support.
- 2009/11/17 [0.16.3] [Included in RAIDiator 4.2.8]
- Fixes for 3GP support for DLNA certification.
- 2009/11/09 [0.16.1]
- Fix JPEG resolution parsing on Duo and NV(+) systems.
- Add XMP parsing for image dates in cases where there is no EXIF data.
- Don't advertise downscaled images to Samsung TVs.
- 2009/11/05 [0.16] [Included in RAIDiator 4.2.7] * Note: Updating will force a rescan.
- Add initial support for 3GP video files.
- Hopefully solve access denied issues with Automatic Updates enabled when copying files from Windows.
- Update file metadata information on an existing file after it is modified.
- Force a rescan in cases where the previous scan did not complete.
- 2009/10/15 [0.16pre6] * Note: Updating will force a rescan. [Included in RAIDiator-x86 4.2.7-T55 Beta]
- First crack at SRT support for Samsung TVs. (Some feedback: viewtopic.php?p=189887#p189887)
- Use band name for audio containers when it's available.
- When clients sort by track, sort by disc first if available.
- 2009/10/13 [0.16pre5]
- QuickTime (MOV) support added, playback device must support QuickTime codec.
- Scale down resolution of images if source is greater than the requested resolution from device.
- 2009/10/02 [0.16pre4] [Included in RAIDiator-x86 4.2.7-T51 Beta]
- Add Popcorn Hour support for using the wrong MIME type for FLAC.
- Fix WAV file extension support.
- Enable JPEG resizing support.
- Add Ogg scanning support.
- Few other misc changes (back-end db,compiler issues).
- [4.2.7-T51] Support for multiple media shares (x86 platform only).
- 2009/07/13 [0.15] [Included in RAIDiator 4.1.6]
- Make .mkv streaming to Samsung TVs work.
- Speed up scanning in conditions where there is very large cover art in a folder with many items.
- Sort TiVo music by track number then name, when TiVo asks us to sort by name.
- With automatic updates enabled, check if a newly-added file is cover art for other existing files, and update their entries if so.
- 2009/06/17 [0.14]
- Don't send video cover art information to XBox 360, since it causes 360 to not display the video at all.
- Fix TiVo beacon issue where it would only broadcast to the first network interface, even if it was not connected.
- Ignore the first file change notification on new files from OSX, since the first file close just creates the file, and then OSX re-opens the file and writes the actual contents. This may fix the "corrupt data" issue some people were seeing.
- Fix a potential scanner crash with a certain type of bad mp4 audio metadata. (thanks gencode)
- 2009/06/04 [0.13]
- Look for file-specific cover art first (mostly useful for video cover art).
- Eliminate a race condition whereby automatic updates might not work after the initial scan completed.
- Make TiVo beacon broadcasts more consistent.
- Add some MIME tweaks for Samsung TVs (should help with AVI video support).
- Fix all known image display resolution issues by working around Freebox's (and others) dependency on image resource ordering.
- Add WAV file support on Denon receivers.
- 2009/05/28 [0.12]
- Improve character set conversion in ID3 tags with some Japanese, Chinese, and Korean tags.
- Add .m4a album art extraction.
- Add basic video cover art support (only external cover art, not embedded).
- 2009/05/27 [0.11.1]
- Fix issue introduced in 0.11 which broke image and video scanning.
- 2009/05/22 [0.11]
- Fix WAV file playback on PS3.
- Follow symbolic links when scanning.
- Fix a scanner crash when encountering audio files with malformed embedded JPEG data.
- 2009/05/11 [0.10]
- Fix automatic updates on modifications to the base of the media directory.
- Add WAV file support.
- 2009/05/10 [0.9]
- Add Windows Media Player support.
- Send file descriptions with a "real" file extention. This could hopefully improve compatibility with more clients.
- 2009/05/04 [0.8] [Included in RAIDiator 4.2.5]
- Fix a potential crash on audio files with very long comments.
- Add version number to the log file.
- 2009/05/02
- Improve client detection.
- Fix incremental browsing (should fix incomplete listing on PS3 and others).
- Fix problem introduced with the last change that didn't handle certain filter arguments.
- 2009/04/30
- Fix TiVo video transfer issue which would cause TiVo to reboot.
- Change AVI MIME types so they will hopefully be more compatible with older playback devices.
- Handle strange filter arguments better.
- Deal with very large music libraries on XBox360. If the library is too large, ReadyDLNA won't sort the files any more under Songs.
- 2009/04/21
- Fix a scanner crash with certain UTF-16 MP3s.
- Fix auto-update handling of jman's sequence of copying a file, deleting that file, then copying the file again.
- Add preliminary TiVo video support.
- 2009/04/17
- Greatly improve scanner performance for very large music libraries. (my test library scan time went from >3 hours to <45 minutes)
- 2009/04/16
- Fix some issues with ampersand escaping.
- Improve image date/camera metadata handling by not storing an invalid date if none exists.
- 2009/04/11
- Initial public release. [Included in RAIDiator 4.1.5]
Message 1 of 7
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-03-07
03:27 PM
2013-03-07
03:27 PM
Re: * ReadyDLNA Update Addons [Updated: 2013/03/07]
Updated with v1.1.0~rc4 release.
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-16
02:42 PM
2014-01-16
02:42 PM
Re: * ReadyDLNA Update Addons [Updated: 2014/01/16]
Updated with v1.1.1.2 release.
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-16
06:55 PM
2014-04-16
06:55 PM
Re: * ReadyDLNA Update Addons [Updated: 2014/04/16]
Updated with v1.1.2.2 release.
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-04-29
06:02 PM
2014-04-29
06:02 PM
Re: * ReadyDLNA Update Addons [Updated: 2014/04/29]
Updated with v1.1.2.3 release.
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-11-13
04:09 PM
2014-11-13
04:09 PM
Re: * ReadyDLNA Update Addons [Updated: 2014/11/13]
Updated with v1.1.4 release.
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-10-14
08:43 AM
2015-10-14
08:43 AM
Could you update for 1.1.5?
Message 7 of 7
