Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 1000s - RAID Offline after disk swap
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-03
05:12 PM
2011-08-03
05:12 PM
Earlier swap out of the first disk worked, but after swapping out the second one the X-RAID is offline. The system did have all HDS725050KLA360 drives, the drives being swapped in one at a time are from one of my other working 1000s.
Info & logs below:
Model: ReadyNAS 1000S
Firmware: RAIDiator 4.1.7 [1.00a147]
Memory: 1024 MB [2.0-2-2-6]
Volume C: Offline, RAID Level , disks, 0% of 0 MB used
The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. BitTorrents addons-scripts media user_home webroot backup tca addons-config
[Wed Aug 3 18:35:51 EDT 2011]
Shares on RAID Volumes
No shares exist.
Ch 1 : Seagate ST3750640NS [698 GB] 696 GB free
Ch 2 : Seagate ST3750640NS [698 GB] 696 GB free
Ch 3 : HDS725050KLA360 [465 GB] 0 MB free
Ch 4 : HDS725050KLA360 [465 GB] 0 MB free
Wed Jul 20 01:04:33 EDT 2011 Powering off device
Wed Jul 20 01:04:32 EDT 2011 Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
Wed Jul 20 01:03:42 EDT 2011 RAID resync failed to start. Please contact Support.
Wed Jul 20 01:02:05 EDT 2011 [BitTorrents] Share contents ownership and permissions changed to match the share.
Mon Jul 18 02:34:29 EDT 2011 A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
Mon Jul 18 02:29:47 EDT 2011 Disk add event occurred on SATA channel 2.
Mon Jul 18 02:29:01 EDT 2011 Disk remove event occurred on SATA channel 2.
Info & logs below:
No shares exist.
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
06:58 AM
2011-08-10
06:58 AM
Re: ReadyNAS 1000s - RAID Offline after disk swap
Hello,
If you have a backup (as the ReadyNAS is a storage system not a backup) you can factory default and rebuild the volume with your backup. If not you will most likely have to contact support. You say swap, do you mean you were upgrading your hard drives?
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources -
Forums:
Knowledge base
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
06:59 AM
2011-08-10
06:59 AM
You may also want to use compressed air to make sure the connections on the NAS itself and clean and free of dirt.
Support Resources -
Forums:
Knowledge base
Support Resources -
Forums:
Knowledge base
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-10
03:48 PM
2011-08-10
03:48 PM
The swapping was h/d upgrading one at a time.
I have recently replaced a fan, so the system was cleaned out then. Unfortunately I don't have a backup, since this NAS is mostly used for Torrents and temporary files before there moved to one of the main NASes. I'll check to see what can be done with supports help.
Message 4 of 4
