- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 104 in X-RAID mode does not expand adding an additional disk
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a ReadyNas 104 (RN104|ReadyNAS 100 Series) running firmware version 6.9.1 and I had only one 2TB (WD Red) drive inserted into it. Everything is working fine but my drive is almost full. So I purchased a new 4TB (WD Red) drive and inserted it into the second channel. After doing this my system has resynced twice and I have rebooted it several times but the storage capacity stays the same.
Could someone please tell me why this is and what do I have to do to expand my storage?
Please find attached a screenshot of the volumes admin page.
If logs are required I'm ready to send them.
Thank You
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DwaineB09 wrote:
If I understand you correctly, as soon as I install that first 8TB drive, that would then become the redunancy drive
There really isn't a "redundancy drive". The parity blocks (which are the redundancy) are scattered across all the drives - and data blocks also are scattered across all drives.
When you add your first drive (2+4+8TB) you will end up with a 6 TB volume size (4 TB bigger than what you have right now). 4TB of space on the 8 TB drive will be unused. The expansion will happen in two phases. First the volume will expand horizontally to 4 TB, then the system will reboot (or perhaps you will need to reboot it), and it will vertically expand to 6 TB.
When you add the second one (2+4+8+8), the system will expand to 14 TB. I'm not sure if there a reboot will be needed for this step or not.
When you upgrade the 2 TB drive (8+4+8+8), it expands to 20 Tb, and upgrading the last one will expand it to 24 TB.
This will work, but the resync times will be long (and take longer for each expansion step). Every data block on the disks is either read or written in each step. As the total size grows, that takes longer and longer.
If you could back up your current volume, it would be faster to do a factory install with 4x8TB in place, reconfigure the NAS, and then restore the files from your backup.
@DwaineB09 wrote:
Also from what I can understand, I could get an 8TB external drive, plug it into the USB slot and use that as my backup drive
Backup is important, though of course over time 8 TB won't be enough for a 24 TB volume.
Almost all 8 TB external drives are SMR technology. Folks have had trouble with them in linux systems, so you might want to research that before purchasing an SMR model. Unfortunately the datasheets often don't say if they are SMR or not.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 104 in X-RAID mode does not expand adding an additional disk
XRAID is designed to give you a redundant RAID array - keeping your data available even if you have a routine disk failure.
So when you added the new disk, the NAS used it to create redundancy, not to expand your storage. You now have a RAID-1 volume (which is mirrored - disk 2 is a copy of disk 1).
The simplest solution is to purchase a second 4 TB disk, and insert that. After the resync, you'd end up with a 6 TB volume (~5.45 TiB). The capacity rule for XRAID is "sum the disks and subtract the largest".
Another option is to
- back up your data
- uninstall your apps
- switch to flex-raid
- destroy your current volume
- create two new volumes (one for each disk)
- reconfigure the NAS, putting some shares on each volume
- restore the data from the backup
- reinstall your apps.
It's not as difficult as it might look, but it is tedious.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Stephen,
Thanks for your reply.
I understand the situation now. In that case could I get let's say an 8TB external drive and attach it to the USB port on the front panel and use that as the redundancy drive?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The NAS will only use internal drives for redundancy. Also, many 8 TB USB drives use SMR technology, which is not well-suited for RAID - so removing the drive from the case, and deploying it internally isn't the best option.
You could create shares on a USB drive, and use that to temporarily to expand your storage. There wouldn't be a redundancy on the USB drive, and the performance would be much slower than an internal disk. But if you have archival material that isn't referenced very often you could use that approach for now. You could of course just also use a USB drive for backup.
FWIW, you only need one 4 TB drive added for redundancy. You'd be using RAID-5, which isn't a mirror. Partity blocks are distributed across the array, and allow any of the three disks to be reconstructed from the other two. In general, the capacity of an XRAID array is "sum the disks and subtract the largest", and the redundancy needed is size of the second-largest disk in the array, So 4x3TB would give you an 8 TB volume, 4x4TB would give you 12 TB. The NAS reports these sizes in TiB, so it would show ~7.2 TiB (not 😎 and ~10.9 TiB (not 12)..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your reply.
OK no problem.
This is my plan, currently I have two drives (a 2TB and an 4TB), I'm goint to upgrade that to a 2,4,8. Afterwards upgrade that to 2,4,8,8, then go onto 8,4,8,8, and finally hve 4 8TB drives.
If I understand you correctly, as soon as I install that first 8TB drive, that would then become the redunancy drive and I would get 6TB of available space in total (disrearding the TiB) and so one. Also from what I can understand, I could get an 8TB external drive, plug it into the USB slot and use that as my backup drive so I would have one internal 8TB drive as my redundancy drive and have an external 8TB drive as my backup drive and in the end have 24TB of available storage.
Would that work?
Is there anything wrong with that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
