Orbi WiFi 7 RBE973
Reply
ReadyNAS 204 Will not shut down fully, shows do_exit+9ec
djrees
When trying to shutdown my ReadyNAS 204 it hangs with an error of do_exit+9ec on display.  The only way to recover is to disconnect the AC power cord and reconnect.   I have the most current version of firmware as of 05/27/17.  Version 6.7.4.  Same error occurs regardless of how it is done. Occurs when shutting down from the power button or from the system device webpage.  Any suggestions?
Had a similar problem when I first purchased this unit.  A beta firmware solved the problem then.  The problem reappeared when upgrading to the next publicly available released firmware.
Please advise.  Thank you.
Model: RN20400|4BAY Diskless Desktop Readynas Storage
Message 1 of 65
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS 204 Will not shut down fully, shows do_exit+9ec
Can you send in your logs (see the Sending Logs link in my sig)?
Message 2 of 65
djrees
Logs sent as requested.  Let me know if you need any other information.
Thank you,
Message 3 of 65
Skywalker
NETGEAR Expert
Do you have anything plugged in to the LAN 2 port?
Message 4 of 65
djrees
Yes,  have cables in both LAN ports.  This problem occurs even with just one LAN port is connected and with bonding off.  Ijust set up LACP this weekend on my switch and NAS.  Works ok for a short while.  Then the top LAN port goes dead on the NAS.  Have tried different patch cords, different switch ports on switch.  Troubleshooting always leads back to the NAS as the problem. I just discovered the top LAN port problem this weekend.
Message 5 of 65
IlSel
Has this issue actually been ever root caused or resolved? I'm now on 6.9 and am experiencing this very same issue. Restart works, but shutdown leads to do_exit_9ec message.
Model: RN204|ReadyNAS204
Message 6 of 65
Skywalker
NETGEAR Expert
There was an issue that was located back in April, where if you had WoL enabled and a WoL magic packet came in while the box was running, it would prevent shutdown.  That's the only shutdown failure that we've been able to reproduce and debug.
If you're seeing issues where you're unable to shut down on 6.9.0, please describe your network, WoL, and power timer configuration.
Message 7 of 65
Skywalker
NETGEAR Expert
Message 8 of 65
IlSel
I'm using a quite simple network setup (default settings): eth0 link only is connected and is passed through UPS filter. The connection to the switch goes through a power line network converter.
Power settings are:
WoL - disabled
Power timer - disabled
Disk spin-down - enabled all the time after 20min inactivity
Message 9 of 65
mdgm-ntgr
If you download the logs what do you see for WoL in network_settings.log?
Message 10 of 65
IlSel
That's what I see. Though a bit cryptic with 'd' or 'dg', I'd assume d = disabled
Settings for eth0:
    Supported ports: [ TP MII ]
    Supported link modes:   10baseT/Half 10baseT/Full
                            100baseT/Half 100baseT/Full
                            1000baseT/Full
    Supported pause frame use: No
    Supports auto-negotiation: Yes
    Advertised link modes:  10baseT/Half 10baseT/Full
                            1000baseT/Full
    Advertised pause frame use: No
    Advertised auto-negotiation: Yes
    Link partner advertised link modes:  10baseT/Half 10baseT/Full
    Link partner advertised pause frame use: Symmetric Receive-only
    Link partner advertised auto-negotiation: Yes
    Speed: 100Mb/s
    Duplex: Full
    Port: MII
    PHYAD: 4
    Transceiver: external
    Auto-negotiation: on
    Supports Wake-on: pg
    Wake-on: d
    Current message level: 0x00000007 (7)
                   drv probe link
    Link detected: yes
Message 11 of 65
mdgm-ntgr
So your router switch has 100Mbit ports not Gigabit (1000Mbit)?
Message 12 of 65
IlSel
That's correct my entire wired network is 100 Mbit and I'm using LAN over power adapters. Does this have any implication on the shutdown behavior?
Message 13 of 65
Skywalker
NETGEAR Expert
I wouldn't expect it to be related, but you never know.
Does this issue happen 100% of the time?  Does it continue to happen if you unplug the network cable before shutting down?
Message 14 of 65
Sandshark
Sensei
This sounds like the NAS is waiting for some process to shut down that is not.  Since this does not seem to be common to all users, I wonder if it might be an add-on causing the issue?
Message 15 of 65
Skywalker
NETGEAR Expert
It's at a lower level than that.  The do_exit location display on the LCD means that all process were already stopped, and the shutdown pin was asserted; so getting to that part of the code is unexpected.  AFAIK, only a wake-on-LAN alarm or a wake-on-RTC alarm can prevent the shutdown pin assertion from taking effect.
Message 16 of 65
IlSel
Apologies for the late reply, wasn't physically co-located with my NAS, but I've done the testing now:
network cable connected: 2 / 3, ie NAS didn't shut down twice out of three attempts
network cable disconnected: 0 / 3, ie NAS shut down all three times normally
Conclusion: Issue is intermittent and seems to be network related. Are you guys sure the fix from April hasn't been dropped accidentially in 6.9?
Message 17 of 65
Skywalker
NETGEAR Expert
I'm positive that the earlier fix is still in place.  So it looks like we'll need to do a little more experimentation.
1) Update to 6.9.1 Beta 2.  This release fixes a problem with the NIC reset code after TX timeout. There's a chance it's related.
2) Try enabling WoL and see if the system shuts down properly.
3) Note the state of the NIC LEDs after shutting down, in both cases where it shuts down properly and when it fails to shut down with the do_exit message.
Message 18 of 65
beschmidt
Was this issue ever resolved? I'm running FW 6.9.3 and I'm getting this same error upon shutdown regardless of whether I'm on the network at work in my office, on my home network, or if the ethernet cable is disconnected. It occurs whether or not WoL is enabled, and if I shut down via the online interface or by "gracefully" powering down the unit with the power button. In any of these situations I receive the do_exit+9ec message and the power LED blinks blue and does not turn off.
Model: RN214|4 BAY Desktop ReadyNAS Storage
Message 19 of 65
mdgm-ntgr
Can you send me your logs (see the Sending Logs link in my sig)?
Message 20 of 65
beschmidt
I emailed my logs as specified in the instructions and I got an automatic reply that delivery had failed to another email. Hopefully they still got to you.
Message 21 of 65
mdgm-ntgr
Thanks for the logs. Yes, I got them.
Message 22 of 65
jasonamd
I've been having the same issue for many months through several firmware versions. Just updated to 6.9.3 and still getting the error on shutdown.
Message 23 of 65
alarma
Hi, Having the same issue on RN21400, the last stable firmware 6.9.3. If I shutdown NAS from buttion, or from admin page, or by everyday timing. After disk's spinn off having do_exit+9ec error on led and blinking power buttion. Please could you help solve this problem. NAS on warranty and worked after buying 7 monthes.
Disk's spinn of disabled.
Power Timer is enabled.
WOL is disabled.
No UPS configured.
Model: RN21400|ReadyNAS 214 Series 4-Bay (Diskless)
Message 24 of 65
evan2
NETGEAR Expert
We reproduced the issue,
Developter is debugging now.
Message 25 of 65
Top Contributors
Discussion stats
Announcements
