× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 424 unresponsive after 30 mins uptime
spwb
My ReadyNAS 424 often goes unresponsive after 30 minutes up time - the front panel buttons only light up blue upon pressing and do not bring up front panel info, and I cannot log into the admin page and I have to shut it down ungracefully (long press on the power button).  I can then start it back up fine.  This problem is intermittent.  I have tried downgrading from OS 6.10.8 to 6.10.7 and 6.10.3 and the problem persists.
Can anyone suggest some troubleshooting or solutions?
I am happy to post logs.
Thank you
Message 1 of 8
Guru
Re: ReadyNAS 424 unresponsive after 30 mins uptime
Have you downloaded the log zip file?
RAIDar also has a diagnostic you might try.
Message 2 of 8
Sandshark
Sensei
Another option is to open an SSH window and run top in it, then see if a process is at 100% CPU at the time it crashes.
Message 3 of 8
Guru
It makes sense to do all three.
Message 4 of 8
spwb
Hi - thank you for the tips.
Re: the logs - Yes, I've downloaded the log .zip file - should I upload the entire archive here?  I'm not sure if it would contain sensitive information - it contains 77 files - which could be relevant?
Re: RAIDar - i've run the diagnostics and it comes back with the following:
Successfully completed diagnostics
System
  • Disk 1 has 16 Reallocated Sectors
  • Disk 1 has 16 Reallocation Events
  • Disk 1 has 408 Current Pending Sectors
  • Disk 1 has 408 Uncorrectable Sectors
Logs
  • No errors found.
Message 5 of 8
spwb
thanks for the "top tip" ha!
I have top running and will keep it open - if/when the system crashes again, I presume top will display the last refresh.
So far the tracker-miner-f command has been using 90%+ CPU for the past 25 minutes (the entire time the readynas has been up)
I'll report any further findings here.
Message 6 of 8
spwb
the readynas has now gone unresponsive to any presses to the buttons on the front panel and the LED is blank. it is still running however, and I am able to browse the disk in windows explorer
top is showing the afpd command utilising 100% CPU
Message 7 of 8
Guru
~400 pending sectors suggest that the disk needs to be replaced.
It could be linked to the unresponsive problem.
BTW, don't post the logs here - there is some privacy leakage.  I'm willing to take a quick look if you like.  Put the zip into cloud storage (dropbox, google drive, etc), and send me a PM with a link (you can't attach it).  Make sure the permissions allow anyone with the link to download it.
Send a PM using the envelope icon in the top right of the router page.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 653 views
  • 0 kudos
  • 3 in conversation
Announcements
