× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 516 with EDA500 Expansion unit issue when started from timer.
kevcompton
Apprentice
Hi,
When the ReadyNAS 516 and EDA500 is automatically started from a set timer sometimes but not always, the follow messages are output and the share on the EDA500 is unavailable:
Disk in channel '1' (eSATA Port 1) changed state from RESYNC to ONLINE.
Disk in channel '2' (eSATA Port 1) changed state from RESYNC to ONLINE.
Disk in channel '3' (eSATA Port 1) changed state from RESYNC to ONLINE.
Disk in channel '4' (eSATA Port 1) changed state from RESYNC to ONLINE.
Disk in channel '5' (eSATA Port 1) changed state from RESYNC to ONLINE.
If I do a manual restart, the issue goes away
Has anyone else had a similar issue?
Thanks.
Message 1 of 15
JennC
NETGEAR Employee Retired
Re: ReadyNAS 516 with EDA500 Expansion unit issue when started from timer.
Hello kevcompton,
The RESYNC to ONLINE messages I believe is normal.
Since you mentioned there is/are share/s that is unavailable, does this mean you have multiple volumes? What's the RAID level?
Message 2 of 15
kevcompton
Apprentice
Hi,
Thanks for responding, i've added screen shots of when EDA1 is successful mounted. When not, the eda1 volume is shown in red and the only option from that screen is to format the drives. As I said, a reboot fixes this. Since posting, I have had 1 occasion where the eda1 volume is unavailable after a manual boot.
Also, I only get the RESYNC to ONLINE messages when there is an issue.
Hope you can help.
Will add a screen shot when it fails again if that helps.
Kevin.
Message 3 of 15
mdgm-ntgr
Which firmware are you running?
Message 4 of 15
kevcompton
Apprentice
It's 6.2.4
Message 5 of 15
kevcompton
Apprentice
This error happened today from a manual start, see screen shot. I have saved the logs but can't see a way of uploading them here.
Message 6 of 15
Guru
@kevcompton wrote:
...I have saved the logs but can't see a way of uploading them here...
You don't. You can email logs to Netgear if you have a support case (or if a Netgear person here is interested). mdgm has the details in his signature links.
Message 7 of 15
kevcompton
Apprentice
Thanks. Do you suggest that I should open a support case for this then?
Message 8 of 15
Guru
If this was purchased after June 1 2014 then you should have free lifetime chat support for this NAS, so I would open a case on this.
Netgear folks engaged here (mdgm, jennc, etc) might also be interested in the logs.
A good way to proceed is open the case, post the case number on this thread, and then email the logs.  Perhaps include a link to this thread in the email.
Then Netgear will be able to tie the case to this thread.
Message 9 of 15
JennC
Hello kevcompton,
I checked your profile and found that you have several legacy ReadyNAS units. This ReadyNAS 516 is not yet registered, this should have free support.
I think your case is for L3 escalation, please contact support center.
Message 10 of 15
kevcompton
Apprentice
Thanks.
I recently updated the firmware to the latest beta and the issue hasn't happened again.
If it does, I will contact support.
Message 11 of 15
JennC
Hello kevcompton,
In case BETA resolves the issue, please let us know. You may also post it at ReadyNAS OS6 BETA release board.
Message 12 of 15
inspectorgadjet
Apprentice
I'm experiencing the same issue with my EDA500. My readynas also sometimes just gets stuck saying booting and I have to power both the nas and expansion chassis off completely and then when I power on again they are fine.
I have a 314 and this happens about once a week. I am on OS 6.4.1.
Message 13 of 15
mdgm-ntgr
Perhaps you could see if ReadyNASOS 6.4.2 (RC1) also resolves the problem for you?
Can you send me your logs (see the Sending Logs link in my sig)?
Message 14 of 15
inspectorgadjet
Apprentice
Thanks. I'll give that a try tonight and will have to let it run for a couple of weeks to see if it still happens because I don't know exactly when it's going to do it. I'll also take a look at sending the logs in the next couple of days.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 4310 views
  • 0 kudos
  • 5 in conversation
Announcements
