- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 524X CPU Temperature
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I've just acquired one of these second hand.
CPU runs about 69oC with fan on cool.
Environment is rather warm (under stairs) but all other NASes there and much cooler.
Found another couple of threads:
I took it apart - unfortunately it looks like the heatsink is glued on with an adhesive thermal pad - once I'd carefully popped all the pins out of the heatsink it was still stuck fast and I didn't want to pry - it certainly wasn't thermal paste like all ther others i've upgraded/repasted.
The current Delta AFB0912HH fan just about keeps it cool but its very noisy. Going to try a Noctua NF-A9 but the peak flow and pressure aren't as high as the Delta full pelt according to the specs (but the RPM in OS6 hovers around 2800-2900RPM whereas the max spec is 3200RPM) - so we'll see if it holds the temperature.
What's the max CPU temperature - i've read elsewhere 82oC??
Any other suggestions??
Cheers
A
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 524X CPU Temperature
-40C to +85C; according to https://en.wikichip.org/w/images/9/9a/xeon_d-1500-platform-brief.pdf
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
Do you know if the NAS has any sort of thermal cut out before then??
- Mark as New
- Bookmark
- Subscribe
- Permalink
No idea, I never had a shutdown caused by overheating of system and/or disk. Anybody else and what was the temperature, please?
In the configurable alerts available through the admin ui of os6 system overheating is not mentioned, while disk and fan are. You might want to take a look.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks.
Just as an update - installed a Noctua 92mm PWM (as goes to 2000rpm) fan - DC control with 3 pins still works fine.
Was hotter - much quieter but CPU temps peaked at 82oC.
Interestingly opened the door on the unit and they dropped 10oC.
Changed the fan direction so it blew in rather than exhaust - temps about 72oC with door closed and about 65oC with door open.
Seems to be a combination of poor case design for airflow and a rather weedy CPU heatsink with thermal adhesive rather than paste.
Thanks all,
A
