× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 526 10GB Connectivity
Jimbo1960
Initiate
Can an RN526x with 10GB ethernet be connected to a 1GB switch?  I know the NAS would not operate to it's full potential.  Is their a special cable involved?
Model: RN526X|ReadyNAS 526X – 6 Bays with up to 60TB total storage
Message 1 of 4
Accepted Solutions
Retired_Member
Not applicable
Re: ReadyNAS 526 10GB Connectivity
Hi @Jimbo1960 , going via copper a cat6 cable should be ok. From wikipedia: "For 10GBASE-T, an unshielded Cat 6 cable should not exceed 55 meters and a Cat 6A cable should not exceed 100 meters." More details here: https://en.wikipedia.org/wiki/Category_6_cable
More details in general about cabling for 10GBASE-T (may it be fiber or copper) here: https://en.wikipedia.org/wiki/10_Gigabit_Ethernet#Copper
However, regarding the speed you can expect between two workstations it will be the slowest component of the path, which limits the result. For example, if you have a GB switch or router between two 10GB workstations you will just get GB performance, though.
Kind regards
Message 2 of 4
All Replies
Retired_Member
Not applicable
Kind regards
Message 2 of 4
Guru
Yes, the NAS will just negotiate normal gigabit.  Any gigabit cable will work in this mode.
Message 3 of 4
Jimbo1960
Initiate
Thanks for all the help.  Sounds like I'm going to buy either the RN526X00 or RN528X00.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 994 views
  • 2 kudos
  • 3 in conversation
Announcements
