Reply
ReadyNAS 6.10.4 6.10.5 rsync whole volume problem
kkwong
My RN314 have 2 volume, each night was schedule to use rsync backup all data to another old NVX, recently I update to 6.10.4 found that backup job complete in a secode without error and actually nothing synced, they try to update 6.10.5 get the same result.
I do some test with by create new backup job to sync the data to new destination and found that:
1. if I use rsync to backup "whole volume", it only sync the folder strurcture to the destintation but no file was synced.
2. if i only rsync to backup only a share then it will sync all data to destintaion as expected.
any idea what should i do ?
Model: RN31400|ReadyNAS 300 Series 4- Bay (Diskless)
Message 1 of 4
Accepted Solutions
Guru
Re: ReadyNAS 6.10.4 6.10.5 rsync whole volume problem
Several others have reported this, but for some reason the fix is very slow in coming.
For now, you can either switch to share-by-share backup or downgrade to 6.10.3.
@JohnCM_S: any update on the status of this problem?
Message 2 of 4
All Replies
Guru
Message 2 of 4
yuvsaha123
thanks for the information.
Message 3 of 4
kkwong
thx for the info, let me try downgrade on weekend
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 148 views
  • 1 kudo
  • 3 in conversation
Announcements
