× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 600 eternal file system check
ultraken
The NAS glitched out during a weekly Windows backup and the file system check was still going after two full days. It would get to around 7-9% done and restart. I had to bypass the file system check so I could use the thing again.
Everything seems to check out--no SMART errors, nothing remotely interesting in the logs in FrontView--but this isn't the first time this has happened. I've had it and the drives in it for over six years now so I'm concerned about its health.
I saved the system logs if it helps.
Message 1 of 2
Guru
Re: ReadyNAS 600 eternal file system check
You could try doing a backup (and saving the config) and doing a factory default/restore. Though it would be prudent to replace the drives while you were at it.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 752 views
  • 0 kudos
  • 2 in conversation
Announcements
