× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS DUO 2nd disk died
Aluz1
Hi,
my readynas duo started to act strange, it was showing me that both disks are dead, But when i connected thru ssh im able to see the data. When i removed the second disk and restarted its still showing me that the second disk is dead and in the frontview is blinking yellow led but the disk is already removed, i think there is something wrong with the readynas itself.
here is a complete dmesg log
http://textsave.de/?p=169242
And here is complete log file what happened so far after i turned the readynas on on 20th
Severity 	Date 	Message
Mon May 6 02:35:23 CEST 2013 Transmission service has been stopped.
Mon May 6 02:28:31 CEST 2013 Transmission service failed to start.
Mon May 6 02:27:45 CEST 2013 Transmission service has been stopped.
Wed Jan 1 01:01:54 CET 2003 System is up.
Mon May 6 01:51:34 CEST 2013 The disk on channel 2 has failed. The NAS will automatically shutdown in 30 minutes to prevent possible data loss resulting from additional failed drives.
Mon May 6 01:51:14 CEST 2013 Powering off device
Mon May 6 01:51:14 CEST 2013 Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
Mon May 6 01:46:37 CEST 2013 System is up.
Mon May 6 01:44:42 CEST 2013 The disk on channel 2 has failed. The NAS will automatically shutdown in 30 minutes to prevent possible data loss resulting from additional failed drives.
Mon May 6 01:44:27 CEST 2013 Rebooting device...
Mon May 6 01:44:27 CEST 2013 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Wed Jan 1 01:27:58 CET 2003 System is up.
Wed Jan 1 01:26:42 CET 2003 Volume scan found and corrected errors.
Sun May 5 22:04:37 CEST 2013 System is up.
Sun May 5 22:03:36 CEST 2013 RAID sync started on volume C.
Sun May 5 22:03:19 CEST 2013 Volume scan found no errors.
Sun May 5 21:36:35 CEST 2013 Rebooting device...
Sun May 5 21:36:34 CEST 2013 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Sun May 5 21:32:48 CEST 2013 The disk on channel 2 has failed. The NAS will automatically shutdown in 30 minutes to prevent possible data loss resulting from additional failed drives.
Sun May 5 21:32:47 CEST 2013 The disk on channel 1 has failed. The NAS will automatically shutdown in 30 minutes to prevent possible data loss resulting from additional failed drives.
Sun May 5 21:32:36 CEST 2013 Blinking disk 1.
Sun May 5 21:26:19 CEST 2013 A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
Sun May 5 21:25:52 CEST 2013 System is up.
Sun May 5 21:23:38 CEST 2013 Volume scan found and corrected errors.
Sun May 5 02:23:27 CEST 2013 A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
Sun May 5 02:22:28 CEST 2013 System is up.
Sun May 5 02:21:41 CEST 2013 RAID sync started on volume C.
Sun May 5 02:19:04 CEST 2013 Volume scan found and corrected errors.
Tue Apr 23 10:13:40 CEST 2013 Disk add event occurred on SATA channel 1.
Tue Apr 23 10:13:34 CEST 2013 Disk remove event occurred on SATA channel 1.
Sun Apr 21 08:34:48 CEST 2013 A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
Sun Apr 21 04:45:55 CEST 2013 System is up.
Sun Apr 21 04:43:28 CEST 2013 System powering off...
Sat Apr 20 21:27:51 CEST 2013 A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
Message 1 of 2
Aluz1
Re: ReadyNAS DUO 2nd disk died
It really looks like the NAS is broken. Because first of all the disks are fire but nevertheless NAS is showing state "Ch 1 : UNKNOWN [1397 GB]" for both channels even if the disks are removed. I just tried to update it but unfortunately without any success on the issue.
I guess i will just have to return it which is kind a disappointing to be after I already returned it one because of other failure.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1155 views
  • 0 kudos
  • 1 in conversation
Announcements
