Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo V2 - Offline Dashboard
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-23
11:50 PM
2012-09-23
11:50 PM
Hello.
I am new to this Forum.
I bought a ReadyNASRND2210v2 on May 8 - 2012, and this weekend i got the Dashboard OFFline problem.
I can access all shares, and it seems, that there is no problem, with the disk's.
I used hours, and hours - copying all my 200Cd's, and ~25DVD's onto the disk's, so i would be very unhappy to make a Factory reset!
I made some miner changes, in share options, before this happend, but i am unsure what the problem is ???
I am not able to download logs.
I am not able to install the newest Firmware, cause Dashboard seems corrupted.
I have been reading aroud this problem, which seems to occour for a lot of users, so i have the following quistions ! ::
1. Can i install new firmware / OS, with "SSH" ?
2. Does anyone know, what the problem is ?
Thanks in advance - Jesper.
Message 1 of 7
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-24
12:31 AM
2012-09-24
12:31 AM
Re: ReadyNAS Duo V2 - Offline Dashboard
1. Yes. First make sure you have a Duo v2 (runs RAIDiator 5.3.x):
Then update
2. To do that some logs would need to be checked. Fortunately you can check some of these via SSH. Please post output of the following
# cat /var/log/raidiator_version
Then update
# cd /tmp
# wget http://www.readynas.com/download/RAIDiator-arm/5.3.6/RAIDiator-arm-5.3.6
# echo /tmp/RAIDiator-arm-5.3.6 > /.cf_update_in_progress
# reboot
# df -h
# tail /var/log/frontview/error.log
# cat /etc/default/services
# cat /etc/frontview/addons/addons.conf
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-24
03:46 AM
2012-09-24
03:46 AM
Okay, thanx....
I will look into it, later today, when i get back home from my work !
Jesper.
Jesper.
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-24
07:27 AM
2012-09-24
07:27 AM
Okay ... everything seems to be working again now 😄
Here is the output of the suggested logs / etc...
Thank good, i am no newbee into Linux... otherwise SSH into the thing, could have caused serius headegde :oops:
Jesper :!
root@nas-:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 681M 3.2G 18% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 914G 315G 599G 35% /c
/dev/d/d 914G 200M 914G 1% /d
** THIS WAS TAKING AFTER DASHBOARD WORKING AGAIN **
root@nas-:~# tail /var/log/frontview/error.log
[Sun Sep 23 12:42:45 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Sun Sep 23 13:32:32 2012] [notice] caught SIGTERM, shutting down
[Mon Sep 24 15:37:29 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.119' does NOT match server name!?
[Mon Sep 24 15:38:35 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.119' does NOT match server name!?
[Mon Sep 24 15:38:49 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.119' does NOT match server name!?
[Mon Sep 24 15:38:49 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
[Mon Sep 24 16:06:14 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.119' does NOT match server name!?
[Mon Sep 24 16:06:25 2012] [warn] RSA server certificate CommonName (CN) `192.168.1.119' does NOT match server name!?
[Mon Sep 24 16:06:25 2012] [warn] pid file /var/log/frontview/apache-ssl.pid overwritten -- Unclean shutdown of previous Apache run?
[Mon Sep 24 16:06:25 2012] [notice] Apache/2.2.16 (Debian) mod_ssl/2.2.16 OpenSSL/0.9.8o DAV/2 Axis2C/1.6.0 mod_apreq2-20090110/2.7.1 mod_perl/2.0.4 Perl/v5.10.1 configured -- resuming normal operations
root@nas-:~# cat /etc/default/services
USER_HOME_DIRECTORY=1
USER_HOME_DIRECTORY_FTP=0
USER_HOME_DIRECTORY_NFS=0
USER_HOME_DIRECTORY_RECYCLE=1
USER_HOME_DIRECTORY_RECYCLE_MAX_DAYS=0
USER_HOME_DIRECTORY_RECYCLE_MAX_SIZE=25000
DISALLOW_PASSOWRD_CHANGE=0
SAMBA=1
NETATALK=1
PROFTPD=0
RSYNC=0
UPNP=1
APACHE=1
NFS=0
NFS_THREADS=1
HTTP_WEBSERVER_SHARE=media
HTTP_WEBSERVER_SHARE_USE_PASSWORD=0
HTTPS_PORT=0
HTTPS_SSL_KEY_HOST=192.168.1.119
UPNPAV=1
READYTIVOD=1
BONJOUR=1
BONJOUR_AFP=1
BONJOUR_FRONTVIEW=1
BONJOUR_PRINTER=0
SNMPD=0
SNMP_ALLOW_HOST=
SNMP_COMMUNITY=public
SNMP_TRAP_DESTINATION=
ATALKD=0
AUTO_CHECK_UPDATE=1
BONJOUR_SUPPORT=1
CSV_USERADD_SUPPORT=1
DAAPD_SUPPORT=1
DAAPD=0
DISABLE_USB_SYNC=1
DISKCACHE=1
DOMAIN_SUPPORT=1
ENABLE_POWERON_TIMER_SUPPORT=1
FLASH_AUTO_COPY=0
FLASH_OWNER=admin
FLASH_PATH=Pictures
FLASH_SHARE=media
FTP_PORT=21
JOURNAL=ordered
LANGUAGES_SUPPORTED=en-us/utf-8,ja/utf-8,ko/utf-8,zh-cn/utf-8,zh-tw/utf-8,ru/utf-8,es/utf-8,pt/utf-8,de/utf-8,fr/utf-8,it/utf-8,nl/utf-8,pl/utf-8,cs/utf-8,sv/utf-8
LANGUAGE=en-us
MONITOR=board_temp,fan,disk_full,quota_exceeded,disk_temp
NTPDATE=0
RESYNC_UNCLEAN_SHUTDOWN=1
RSYNC_SUPPORT=1
SHAREACCESS=SAMBA,NETATALK
SHUTDOWN_ON_DISK_OVERTEMP=1
SNMP_SUPPORT=1
SNMP=1
SSHKEY=rsa
UDHCPD=0
UPNP_SUPPORT=1
UPNPAV_SUPPORT=1
WIZD=0
WIZD_SUPPORT=0
TEMP=0,0,0
FAN=1,0,0,0,0
RAID_MODE=0
ENCODE=utf-8
SUPPORT_UTF8_NAMES=1
ALLOW_UTF8_NAMES=1
FTP_MODE=anonymous
SMTP_PROVIDER=Gmail
SQUEEZEBOX=1
SSH=1
NOFLUSHD=0
READYNASVAULT=0
READYNASREMOTE_SUPPORT=1
READYNASREMOTE=1
WAKE_ON_LAN=1
WINBIND=0
ENABLE_POWERON_TIMER=0
READYNAS_PHOTOS_II_SUPPORT=1
READYNAS_PHOTOS_II=1
LEAFP2P=1
READYDROP=0
APPGENIE=0
AUTOMATIC_VOLUME_EXPANSION=1
root@nas-:~# cat /etc/frontview/addons/addons.conf
SQUEEZEBOX!!Logitech Media Server!!7.7.2!!/etc/frontview/addons/bin/SQUEEZEBOX/start.sh!!/etc/frontview/addons/bin/SQUEEZEBOX/stop.sh!!Other!!detail_url==http://www.logitech.com/speakers_audio/wireless_music_systems::icon_url==/addons/SQUEEZEBOX/icon.png
READYNAS_PHOTOS_II!!ReadyNAS Photos II!!1.0.6!!/etc/frontview/addons/bin/READYNAS_PHOTOS_II/start.sh!!/etc/frontview/addons/bin/READYNAS_PHOTOS_II/stop.sh!!Other!!current_url==http://www.readynas.com/download/addons/arm/current/READYNAS_PHOTOS_II_CURRENT.xml::detail_url==http://www.readynas.com/photos2
DAAPD!!FireFly!!1.0.3!!start-stop-daemon -S -q -x /usr/sbin/mt-daapd!!start-stop-daemon -K -n mt-daapd
Jesper :!
root@nas-:~# df -h
SAMBA=1
NETATALK=1
PROFTPD=0
RSYNC=0
UPNP=1
APACHE=1
NFS=0
NFS_THREADS=1
HTTPS_PORT=0
UPNPAV=1
READYTIVOD=1
BONJOUR=1
BONJOUR_AFP=1
BONJOUR_FRONTVIEW=1
BONJOUR_PRINTER=0
SNMPD=0
SNMP_ALLOW_HOST=
ATALKD=0
AUTO_CHECK_UPDATE=1
BONJOUR_SUPPORT=1
DAAPD_SUPPORT=1
DAAPD=0
DISABLE_USB_SYNC=1
DISKCACHE=1
DOMAIN_SUPPORT=1
FLASH_AUTO_COPY=0
FLASH_OWNER=admin
FLASH_PATH=Pictures
FLASH_SHARE=media
FTP_PORT=21
JOURNAL=ordered
LANGUAGE=en-us
NTPDATE=0
RSYNC_SUPPORT=1
SNMP_SUPPORT=1
SNMP=1
SSHKEY=rsa
UDHCPD=0
UPNP_SUPPORT=1
UPNPAV_SUPPORT=1
WIZD=0
WIZD_SUPPORT=0
TEMP=0,0,0
FAN=1,0,0,0,0
RAID_MODE=0
ENCODE=utf-8
ALLOW_UTF8_NAMES=1
FTP_MODE=anonymous
SMTP_PROVIDER=Gmail
SQUEEZEBOX=1
SSH=1
NOFLUSHD=0
READYNASVAULT=0
READYNASREMOTE=1
WAKE_ON_LAN=1
WINBIND=0
LEAFP2P=1
READYDROP=0
APPGENIE=0
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-09-26
07:14 AM
2012-09-26
07:14 AM
Soo everything is working... another fault is comming ???
Strange ... Any ideas ????
On the REMOTE Access, the internet connection is OK
The Fault is that it says on second BOX : "Could not attach the device"
Jesper.
Jesper.
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-08
11:16 AM
2012-10-08
11:16 AM
@Jesper: Did you manage to fix your issue? I've just updated my firmware and have the same error :oops:
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-10-08
04:45 PM
2012-10-08
04:45 PM
Probably better to discuss the Remote issues in the ReadyNAS Remote forum: http://www.readynas.com/forum/viewforum.php?f=75
Message 7 of 7
