Retired_Member's avatar
Retired_Member
May 06, 2018
ReadyNAS Duo V2 windows timestamp backup problems
My Duo v2 has stopped running backups from my local Windows PC. I have inputted the correct host name, but then if I input the path e.g. backup without a / it fails to work, but says successfully connected to <localpcname>//backup, but then when I run the backup it fails.
Any ideas anyone please? I have tried updating the firmware & have reset it factory defaults twice, but still not working.
  • StephenB's avatar
    If you are running Windows 10, then you should go into "turn windows features on or off" and make sure the SMB/CIFS 1.0 server is installed.
    Guest access is something that Microsoft is starting to lock down, so you might also need to specify the windows logon/password in the backup job.
    A work-around approach is to install a backup tool on the PC that uses a NAS share as a destination.
    • Retired_Member's avatar
      Retired_Member
      The share name is w$ an adminstrative share, which strangely worked last week, but now has stopped. I specify the username and password also. Tried installing SMP Server, without success.
      It seems that the path field will not work without putting a / in first.
      • StephenB's avatar
        The v2 firmware hasn't changed for years now, so this must be something on the Windows side.  Do you need to use an administrative share (instead of a regular share)?
        If you are using the hostname of the PC, you could also try switching to it's IP address.
        If I understood you correctly, the backup also fails with the /.  Am I correct on that?
ProSupport for Business
