- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo connection failed on new iMac
- Mark as New
- Bookmark
- Subscribe
- Permalink
My old iMac died and I got a new one and transferred everything using a Thunderbolt cable. I can see the ReadyNAS drives, but when I click on them, it says "Connection Failed." I installed RAIDar_Mac_4_3_8.dmg on the new computer in case that was the problem, but it still isn't connecting.
I have a client that needs something urgently and I can't access my files!
RND2000-100NAS
iMac OS X El Capitan
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Carrie142 wrote:
It says NETGEAR ReadyNAS Duo RND2000 v2 on the bottom.
Read the link I posted.
@Carrie142 wrote:
There is an ethernet cable running from the drive to my computer. So it isn't physically connected to my router. I'm not sure if it connects to it over wifi?
Normally the NAS is connected to your router. You should then be able to access it over WiFi connections. NAS-> "Network Attached Storage".
How did you access the NAS before you upgraded the MAC?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Duo connection failed on new iMac
I just installed RAIDar_6.0 and that didn't help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you recall which firmware is on the NAS (or can you see it in RAIDar)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure what firmware is and I RAIDar doesn't detect anything connected to my computer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the cd it came with. Would that help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found this http://kb.netgear.com/app/answers/detail/a_id/21029 and wondered if locally updating the firmware on the ReadyNAS might be the solution. I put RAIDiator-arm-5.3.11 (is that the correct file?) on a flash drive and plugged it into the ReadyNAS. But I don't know how to get to that screen where it says to "Select Configure > System > Settings, and click Update."
- Mark as New
- Bookmark
- Subscribe
- Permalink
The part number in the post says you have a duo v1 (which runs 4.1.x firmware). the current production version is 4.1.14, though 4.1.15-T3 "beta" is better - it isn't really a beta, rather it has a few important security updates that are missing in 4.1.14.
There is more info on v1/v2 model identification here: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The screen in your link is for the v2, and you have a v1. Normally the NAS is updated from the web ui - of course that isn't possible if the NAS network connection isn't working.
Is the NAS connected to your router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It says NETGEAR ReadyNAS Duo RND2000 v2 on the bottom. There is an ethernet cable running from the drive to my computer. So it isn't physically connected to my router. I'm not sure if it connects to it over wifi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just read the article you posted and it said to ignore the sticker on it that says it's a v2. Oooookay. I have a v1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was hooked up the same way on my old iMac. Ethernet plugged into the computer. I would go to the Finder window and click on the drive to access the contents. The drives show in the Finder on the new iMac, but it won't connect. I'm getting the impression the old drive isn't compatible with the El Capitan OS.
And I did read your link. I answered before I read it so you would know why I thought it was v2. Just trying to give you quick responses.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to install 4.1.15-T3 but it said, "There is no application set to open the document “RAIDiator-4.1.15-T3”. Search the App Store for an application that can open this document, or choose an existing application on your computer."
- Mark as New
- Bookmark
- Subscribe
- Permalink
I re-read everything you said and tried plugging the ReadyNAS into the router (out in the living room by our tv) and it worked!!!! I'm not sure why it didn't work the way I had it set up with my old computer, but I'm so glad it's working now! Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great!
@Carrie142 wrote:
...And I did read your link. I answered before I read it so you would know why I thought it was v2. Just trying to give you quick responses.
Got it. The labels are confusing. Netgear made a poor branding decision when they launched the v2 platforms, and both the forum and Netgear support are still paying for it.
It sounds like you were trying to install it on the mac. Now that you can reach the NAS web interface, you can try installing it from system->update if you wish. Click on the "local" tab, then "choose file". Select 4.1.15-T3 at that point, and then "upload and verify". After that you can install it.
T3 isn't really a beta, it has some security updates that 4.1.14 doesn't have. Netgear released it as "beta" to make it available sooner.
