- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo v2 USB recovery procedure?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dear community
After having troubles with my ReadyNAS Duo v2 (poor performance of about 0.3 kbps read access) I consulted diffrent formus.
In one of that is was mentionned tro upgrade the firmware to the latest versions.
I've tried several times over the internet - without success. Even if in the log file it was written, that the version 5.3.11 was installed and after the next reboot it will be ready, it was not.
Then I tried ones to set the default parameters and since then I am not able anymore to access the device.
So I am now looking for a procedure to reinstall the firmware over the USB device, since I am not able anymore to use the dashboard.
Thanks for any helpful support, because all that has been found so far didn't work 😞
Kind regards
Zoegge
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Duo v2 USB recovery procedure?
Hi Zoegge,
Welcome to the community!
It would be better if we could further isolate the problem that you have experienced. If its possible, let's eliminate network issues (if there is). Connect your PC to the ReadyNAS via LAN then try to detect and access it using RAIDar and File Explorer. If the same speed or performance issue persists, let's use or setup your ReadyNAS using a fresh disk.
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm far from convinced that USB Boot Recovery is needed here.
USB Boot Recovery is only useful if the firmware on the flash is corrupt and from the symptoms you have described that sounds unlikely. A problem on the OS partition on the disks is much more likely.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It appears one of your disks is bad.
