× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Management services offline
bernd-76139
My RN204 , SN 4602545P00073,   continously operating    shows this fault. I've installed 4 dics, each 1.5 TB, free space abt 900 GB.  Can't acces to admin page, nor to shares but to an 600 GB ISCI section.  System is operating on the  discs,  no info on display  and   pwr  button  does not   react. Downloading protocols does not work: asks me for login, but doesn't accept  pw.
FW is 6.9.0 (since several weeks)
Model: RN204|ReadyNAS204
Message 1 of 6
Guru
Re: ReadyNAS Management services offline
Does https://nas-ip-address/fwbroker respond?
Did you have apps installed (either from the web ui or manually through ssh)?  If so, which ones?
Message 2 of 6
bernd-76139
Tries for handshake, but nothing happens. No apps installed. System was standby with open files on windows, when I came back after one hour network folders were down.
Message 3 of 6
Guru
You might need help from paid support for this.
Alternatively, if you have a backup you could do a factory reset (painful, but effective).
Message 4 of 6
evan2
NETGEAR Expert
Could do you please downloading using RAIDar?
You may download RAIDar from here,
https://kb.netgear.com/27391/ReadyNAS-RAIDar-6-0,
if RADIar can download logs, please send to  nsbu_logs@netgear.com.
Message 5 of 6
bernd-76139
Solved. My son reported that he had the same problem with his RN204, and unplugged power. So I did the same - and it booted. Now scubbing, seems ok. Protocols will be sent. Thank you.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 776 views
  • 0 kudos
  • 3 in conversation
Announcements
