Orbi WiFi 7 RBE973
Reply
ReadyNAS NV (original) exhibits strange booting behavior
AA2769
I have a 7 years old NV box made by Infrant with two 250GB Seagate Barracuda drives. I hadn't used it for a while, but felt suddenly motivated to build a personal cloud. So, last weekend, I fired it up - it booted fine with two disk lights showing up. But, I could not access it using the latest Raidar software so I decided to do a factory reset. I had no data on the drives as it is.
After the factory reset, I started getting a corrupt root message and I could not shut down the box gracefully. After reading through the forum, I then tried to reinstall the OS a couple of times, but to no avail. I pulled out the drives and got them tested - both checked out fine. After reinserting the drives, the corrupt root problem persisted.
In order to figure out if the drives were bad, I pulled out a disk and inserted the other disk in a different tray for every separate boot attempt. One of the disks continually showed corrupt root, so I thought may be that disk is bad. With the second disk, I was making progress or so I thought because instead of corrupt root, I started seeing bad disk detected.
But interestingly, Raidar always showed a bad disk light in an empty tray! And, depending on which try the drive was inserted in, the booting would get stuck at different points and while the disk present light would glow, but not the right one. After much reading, I tried to do a USB boot recovery using the latest firmware. The drive flashed a couple of times and then nothing happened for hours except the power light flashing softly - it never shut down as it should have. I finally yanked the power cable and rebooted the device and tried to install the OS again. The box then would get stuck while Installing - the power light would continue to flash softly. The activity light and the disk lights were off.
Today, I started the process again and changed the drive bays. Now, I am getting corrupt root with this drive too. Completely flummoxed at this point. So, my questions are:
1. Is this box dead or is there some hope? I am willing to spend some more time if there is any hope at all. I don't think the box is bricked, because something is happening. I can also hear the drives turning for some time before everything but the fan goes silent.
2. I can go out and buy new drives, but don't want to do it unless there's a chance of making this box usable.
Any help or pointers from anyone would be much appreciated. I am willing to pay NetGear tech support if they can take a look at this.
Thanks!
Message 1 of 33
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS NV (original) exhibits strange booting behavior
Try running the memory test. You might have a bad memory module.
Also connect the SeaGate disks up to your PC and run SeaTools.
Message 2 of 33
Guru
If the drives check out, try deleting the partitions on the drives on a PC (with windows, right-click on computer, select manage, and then delete the volume in the disk manager section). Or use the write test in seatools, which also effectively deletes the partitions.
Message 3 of 33
AA2769
Thanks! Will try running the memory tests first.
I have also filed a trouble ticket. Case # 22870000.
Message 4 of 33
AA2769
It looks like I can't even get to the memory test. The LEDs only flash four times by my calculation. I am assuming that I should ignore the first couple of really super brief flashes and count from the first slow flash. Am I doing something wrong?
Message 5 of 33
AA2769
I have tried this a multiple times. Also reseated the memory module, but still no luck. I can't get to the memory test mode at all. Should I try and replace it and see if that works? Any pointers as to which memory works best as Netgear doesn't have a verified memory module anymore.
This part here seems to be the correct one: http://www.crucial.com/store/partspecs.aspx?IMODULE=CT3264X335, but it has four chips, while the original memory has 8. I remember reading a discussion on the forum where it was also said that the module with four chips won't work. Is that still the right approach?
Crucial does say this:
"The number of black components on a 200-pin SODIMM can vary, but it always has 100 pins on the front and 100 pins on the back, for a total of 200. 200-pin SODIMMs are approximately 2.625 inches long and 1.25 inches high, though the heights can vary. Like 144-pin SODIMMs, 200-pin SODIMMs have one small notch within the row of pins; however, the notch on the 200-pin SODIMMs is closer to the left side of the module."
I am running out of ideas so all help I can get is appreciated.
On a separate note, Netgear has basically told me that the box is out of warranty and they can't do much, but are still continuing to be in touch. That's awfully nice of them.
Message 6 of 33
AA2769
I replaced the original memory module with another 256MB DDR PC2700 module and tried running the memory test. It seems I can not run the test at all - even after holding the power switch for over 25 seconds, the LEDs did not flash more than 4 times. At about 45 seconds, the LEDs flashed and now I have solid LEDs indicating drives bays 2 and 4 are populated (which actually is not true) and the power LED is flashing rapidly.
Is my unit busted for good? I would like some pointers/help from ReadyNAS gods on this forum. It the unit is bad, I am ready to toss it and move on, but would like to salvage it if someone can help. Netgear can't help.
Strangely, the one that came with the unit is actually a PC3200, when the spec says PC2700.
Message 7 of 33
Guru
Of course we don't know that the original memory was at fault. Since the new memory doesn't seem to work at all, basically we still don't know. You might as well put the original memory back.
Did the drives check out? Do you have a spare drive you could use to test the NAS?
Message 8 of 33
AA2769
I don't have anything to test the drives with. But, I did remove them had them tested by a laptop repair shop. The guy said, they checked out fine and he said he put them back into basically what you get from the factory condition.
Message 9 of 33
Guru
Meaning that he unformatted them, and destroyed all the data on them? Hopefully he asked first.
If so, try putting one drive back into the NAS and start it up.
Also, did he give you a printout of the SMART stats? People have different ideas on what "fine'" means for disk drives - they often degrade without completely failing.
Message 10 of 33
AA2769
I didn't have much data so it was OK to get reformatted 🙂 He did not give me SMART stats.
I have tried one drive, both drives, various combinations and various slots. The end result is always corrupt root.
I have also figured out that my unit has the original bootloader. I was able to put it into the TFTP mode, by looking at the lights guide. The LEDs on top of disks 1 & 4 are solid green while the blue power LED flashes. The unit is certainly expecting data from a TFTP server. Another thing - when I do a factory reset with no drives inserted in the device, obviously, it does not complete booting completely, but I am able to shut it down using the power button.
This behavior leads me to believe that while the drives may be checking out as far the repair shop goes, they may be degraded enough for the NAS to do anything with. I also think that my unit is basically fine - it's just that the bootloader and the software are fairly old and I shouldn't bother playing with it till I change the drive.
I was just thinking of ordering a RE3 WD1002FBYS and testing it out. If that still doesn't work, I can always put it in an enclosure and use as a backup disk.
Thoughts?
Message 11 of 33
AA2769
So, I finally went out and bought a USB 2.0 external disk drive enclosure. I then downloaded SeaTools and connected the drive. I get failures on long generic tests. Does this mean that the drive is busted? SeaTools help does indicate that bad sectors on internal drives cannot be fixed.
Message 12 of 33
mdgm-ntgr
Yes
Message 13 of 33
AA2769
OK - thanks. Tomorrow, I will try booting the readyNAS unit with a brand new WD RE3 drive
Message 14 of 33
AA2769
Getting corrupt root even with the brand new drive. I think all is lost unless someone has any suggestions for fixing this.
Should I try USB boot as a last resort?
Message 15 of 33
AA2769
I tried USB boot recovery - no luck. The USB drive flashes for a second and then nothing happens. The power light keeps flashing for a long time. Now trying the final step - TFTP boot recovery.
Message 16 of 33
mdgm-ntgr
Would not try boot recovery yet.
Does the NAS boot into tech support mode if you select that boot menu option?
Message 17 of 33
AA2769
I do not know if the firmware I have has a tech support mode - the closest seems to be the factory boot option. It has the following modes per http://www.readynas.com/download/docume ... AS-LED.pdf. Although I must say that I have never been able to get into the memory test mode at all.
If I release the power button after the first flash, the system does show that there are no connected disks but Raidar does not detect it. I removed all disks for the time being. Should Raidar detect it or is there some other way to tell? Although I am able to gracefully shut down the system at this point.
I am wondering if I should install on old version of Firefox and see if it can connect to the IP?
Power switch pressed while power on
1st Blink at 5th second: Factory boot option, do not use
2nd Blink at 10th second: TFTP Boot / Setup TFTP server at 192.168.125.1 with kernel_conf, initrd_conf and service files
3rd Blink at 15th second: Factory boot option, do not use (Please press front power button to gracefully shutdownand reboot NAS if you run into it by mistake)
4th Blink at 20th second: USB Boot Use Raw-writer service images from tech support.
5th Blink at 25th second: Memory test: See above memory test LED patterns for test progress and result readings.
6th Blink at 50th second: TFTP recovery (System will start to boot at 53rd second even you keep pressing power switch) / Setup TFTP server at 192.168.125.1 with kernel_init, initrd_init and recovery images
Message 18 of 33
AA2769
Just realized that I had disconnected the Ethernet cable. Raidar is able to detect the box and show that there are no disks. But, I don't know if It's in tech support mode.
Message 19 of 33
AA2769
One more update - Firefox cannot connect to the IP and neither does Telnet, although Ping works.
Message 20 of 33
Guru
The system won't boot without disks. The OS is on the disks!
Message 21 of 33
AA2769
Ah! OK. I will insert the drive and retry this process and send an update.
Stephen and mgdm, I really really want to thank you guys for your help.
Message 22 of 33
AA2769
OK - here's an update: The system boots only after I do a factory reset. However, once I click on setup, volume creation fails and the status goes to corrupt root. The system cannot boot in the tech support mode or the factory boot mode, whatever you want to call it. Although, funnily enough, it shows disks as being present in the first and second bays before going corrupt root. In any case, I am unable to access the system using Firefox or Putty. However, Ping works.
Just for the heck of it, I did another factory reset and found something interesting - I clicked on locate after the system booted and all disk lights flashed. I clicked on the dialog box and the system vanished from Raidar only to reappear a bit later. Now, the light on top of the 4th disk bay is lit, activity light is flashing fast and power LED is flashing slow. Per the light pattern guide, this shows volume expansion, but I am doing no such thing.
The volume creation process started automatically after this with the same result 😞
Message 23 of 33
Guru
Did you try a reset with only one drive installed?
Message 24 of 33
AA2769
Yes I did. I get to the screen where Raidar shows setup and format buttons highlighted.
Message 25 of 33
Top Contributors
Discussion stats
  • 32 replies
  • 3865 views
  • 0 kudos
  • 4 in conversation
Announcements
