Orbi WiFi 7 RBE973
Reply
ReadyNAS NV (original) exhibits strange booting behavior
Guru
Re: ReadyNAS NV (original) exhibits strange booting behavior
So set it up with the one drive. Then try adding the others in turn (waiting for each to sync) and see where you get into trouble.
Message 26 of 33
AA2769
But, the setup itself does not work with a single drive - it ends in corrupt root during volume creation. This is a brand new drive. Should I still add more drives?
Message 27 of 33
Guru
How big is the new drive? Also what firmware is running on the NV?
When it first came out, the NV worked with drives less than 2 TB (which was all that existed back then). 2TB drives support was added in 4.1.7 firmware, but won't work with firmware older than that. Drives > 2 TB can't be used, as the firmware doesn't support GPT formatting.
If the new drive is less than 2 TB, then perhaps try another one - since sometimes they are defective out of the box. You could also try running the manufacturer diags on the one that failed.
Though it could be other components that are failing - a bad SATA backplane or system board for example.
Message 28 of 33
tony359
Apprentice
I'd give it a go. After all the next step is the skip 🙂
Message 29 of 33
AA2769
The new drive is 1TB and the firmware is the original one, v2.x. I will try manufacture diagnostics. I am actually suspecting either the SATA backplane or the processor bootup flash - some sectors might have corrupted causing this issue.
Message 30 of 33
AA2769
I suppose so. A huge paperweight :shock:
Message 31 of 33
Guru
You'd probably find some takers for the drive trays if you sold them used (with the screws of course!). They are hard to find.
Message 32 of 33
tony359
Apprentice
Here I am! 🙂
Message 33 of 33
Top Contributors
Discussion stats
  • 32 replies
  • 3760 views
  • 0 kudos
  • 4 in conversation
Announcements
