× NETGEAR will be terminating ReadyCLOUD service by April 1st, 2023. For more details click here.
Reply
ReadyNAS NV+ v2 Slow MAC browsing
gaz8080
Hi,
We have a couple of Macs running high sierra. Browsing shares on the ReadyNAS is very slow, can anyone help?
Thanks,
Gaz.
Model: ReadyNAS-NV+|ReadyNAS NV+
Message 1 of 9
Guru
Re: ReadyNAS NV+ v2 Slow MAC browsing
The NV+ is end-of-life, so there isn't a lot that can be done.
What firmware are you running?  Are you using AFP or SMB?
Message 2 of 9
gaz8080
Hi Stephen,
Thanks - Firmware is 5.3.1.1. Both SMB and AFP are enabled, browsing shares is slow using both.
Message 3 of 9
Guru
You could try disabling SMB signing on the Mac.  https://support.apple.com/en-us/HT205926
Message 4 of 9
gaz8080
Hi Stephen,
Thanks again. I tried this, it didn't seem to make any difference though.
Message 5 of 9
aks
Virtuoso
Virtuoso
I have this setup and don’t notice mac slower than windows machines. What do you experience when browsing vs transferring files?
-- Tony
Message 6 of 9
gaz8080
Hi Tony,
Maybe it's slow because the share is large, 6811 folders (and growing) each with many subfolders, about 4tb in total.It's NTFS formatted, maybe that's why it's slow?
Message 7 of 9
Guru
Internal volumes are EXT formatted.
The only way it can be NTFS formatted is if you are sharing a USB drive connected to the NAS.  Is that what you are doing?
Message 8 of 9
gaz8080
OK thanks, right click, properties in Windows says it's NTFS. No, it's an internal volume.t's really fast browsing in Windows Explorer, just slow on the Macs.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1447 views
  • 0 kudos
  • 3 in conversation
Announcements
