- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS NV+ v2 adding 3rd drive volume problem...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Installed the first two drives in my NV+ without a problem, with full disk capacity recognised and available, all running Raid 0, but when I added Disk 3, which is a nominal 3TB capacity Seagate, on the disk compatability list, only a small 746GB volume appears and the rest of the disk space is missing/unavailable.
How do I add & access the other volume on disk 3, which is acknowleged as present by Windows disk management software interogation if I plug the drive into a usb sata interface card?
Disk 1 - Seagate ST2000DM001-1CH164 [1863 GB]
Disk 2 - WDC WD20EARX-00PASB0 [1863 GB]
Disk 3 - Seagate ST3000DM001-1CH166 [746 GB]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS NV+ v2 adding 3rd drive volume problem...
You almost certainly have an NV+ v1, which is limited to 2 TB drives.
The easiest way to confirm this is to check the firmware. 4.1.x is for the v1, 5.x.x is for the v2. There are more details here: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Assuming I am correct on the platform - there is no workaround. The v1 doesn't support GPT formatting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are correct, firmware version is 4.1.14, after recent update.
Interesting link, especially info on rear stickers found on these boxes 🙂
Thanks for your help.
