× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS NV+ working fine but front panel LED's don't work at all
Slegnor
Follower
Just got a ReadyNAS NV+ with 8tb storage for very cheap, it all works in terms of the discs/RAID etc but the front panel lights dont work other than the blue one behind the power button.
The backup button appears to work as I get a notification on the web dashboard when it's pressed and the LCD panel works fine.
it's running RAIDiator 4.1.15 [1.00a043]
Any ideas if they've just blown (and can they be replaced) or is it a known problem?
Model: ReadyNAS-NV+|ReadyNAS NV+
Message 1 of 2
Guru
Re: ReadyNAS NV+ working fine but front panel LED's don't work at all
The lights should work, it is not a known issue with 4.1.15.  AFAIK they are not user-replacable.
Your NAS is quite old (discontinued in 2011).  It's limited to 2 TB disks, and it's transfer speeds are much slower than current units (it is limited by the sparc CPU).  Mine is also still in service, I use it as a backup NAS.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2040 views
  • 0 kudos
  • 2 in conversation
Announcements
