× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Pro 4 — ERR: Could not properly extract
chrismo2001
Im haveing that same issue and need help from someone to restore my firmware. I did a factory restore and now its stuck in "booting." when I try to reinstall OS it tells me "err: can not extract" I cant figure out how to get it to USB boot mode. I'm about to pull my hair. I see that people get it fixed, but there is no solution posted.
please help. thank you.
Model: ReadyNASRNDP4410D|ReadyNAS Pro 4
Message 1 of 8
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS Pro 4 — ERR: Could not properly extract
Rebooting. Your NAS should now be not only fixed but also running the latest firmware RAIDiator-x86 4.2.30.
Message 7 of 8
All Replies
evan2
NETGEAR Expert
Message 2 of 8
chrismo2001
Ive tried that, and I can never get it to boot into USB mode. I dont think this model has that option. I used a stop watch and counted 15 second and still it doesn't work. I used 2 different USB's
Message 3 of 8
mdgm-ntgr
It does support that. Have you tried pressing the backup job button for longer than 15 seconds?
You press and hold the backup button
Press the power button briefly to turn the NAS on
Continue to hold the backup button till after seeing a message on the display on the front of the NAS that indicates that it is booting from USB.
Message 4 of 8
chrismo2001
I have. Im on the 3rd usb. I hold it down and it just gets stuck on a blinking course on the LCD. Doesn't do anything. I have formatted it properly and followed all the instructions.
Message 5 of 8
mdgm-ntgr
O.K. I've sent you a PM with an alternative suggestion.
Message 6 of 8
mdgm-ntgr
Message 7 of 8
chrismo2001
WOW!!! Thank you so much! I figued you needed to telnet into it to fix whatever was going on.
Again! Thank you so much!!!!! 😄
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2798 views
  • 1 kudo
  • 3 in conversation
Announcements
