- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Pro Pioneer - Solutions Please - Bad controller?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah the most dreaded topic. I've gotten a bit complacent since it's been so reliable, I double back up but not everything 😞 and of course I need it sigh.
So I shut my pro pioneer down to replace the battery in the UPS it was connected too. Now it won't power up!
I figure no big deal, I have a 550w power supply lying around, I'll just plug it all together to get it running again. I get the wiring all sorted out and the power supply keeps tripping out.
I tested no drives plugged and it still trips out.
I tested with the 3 molex disconnected and it looks like it boots ok (I didn't bother going very far with it)
I tested individual molex and it looks like only the top one is ok that doesn't trip the system. the bottom two make power supply trip out or something.
I guess bad controller?
Anything else I should try? what are my options?
Thank you for your time
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well one option would be to get a new x86 ReadyNAS. You may find this article helpful: http://kb.netgear.com/app/answers/detail/a_id/29875/~/readynas%3A-migrating-disks-from-raidiator-to-...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Pro Pioneer - Solutions Please - Bad controller?
Oh that sounds easier than I thought!!! I thought I needed the exact same older model
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well you would need somewhere to backup your data to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's the least of my worries, I can get it going, pick what I really needed... then figure out where to put 9TB of data after 😄
- Mark as New
- Bookmark
- Subscribe
- Permalink
so anything 516 and higher would be ok? Time to decide how fast I need 😄
- Mark as New
- Bookmark
- Subscribe
- Permalink
actually probably more like what I can get the fastest
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's possible the replacement PSU is bad/incompatible or there is some other hardware issue.
You could get the RN316 or RN516 or RN716X or one of our brand new models just released the RN526X or RN626X.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did wonder about power supply being not compatible but I made sure each had it's own lane, not all share off the same bunch of wires. It's modular so maybe it's the cable? Worth a shot to see if the best responding cable helps the other two.
I actually tried a 2nd power supply with similar result.... I think I blew that 2nd power supply though as the computer I borrowed the PS from is not able to stay powered up and boot 😞
In Canada it looks like the best one available is the RN516.... seems like only amazon.ca has it... not really found in my local shops for some reason. Other vendors look to be taking over. I can't even see the RN716X on the netgear site. I don't mind getting a powerful one but server and Xeon processors almost seem too overkill for my needs 🙂 316 very available but that's a downgrade from my pro pioneer...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RN516 is a decent upgrade over the RN316. I love mine. I use it with Plex and it does a great job of transcoding.
The RN526X and RN626X were only just announced at the start of the month. Availability of these two should improve over the coming weeks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I found a place with RN526X locally.... rather get the new one that one that's going onto 3 years!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hmm just saw this in my email, that's not good is it....
Missing shares detected (nas-E7-16-02) - - Gmail
The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. VirtualDrives publicftp openstor media installs doc webroot backup bfhl Pictures |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like it is probably a data recovery situation. Contact support and they can inform you of the costs.
You could send me your logs (see the Sending Logs link in my sig) and I could confirm this first if you like.
- Mark as New
- Bookmark
- Subscribe
- Permalink
still getting emails.... so confusing is it working or not 🙂 lol
New ReadyNAS firmware available (nas-E7-16-02) -- Gmail
A newer version of the firmware for your ReadyNAS device is now available. To install it, please go to the System page and click on the Update tab. Then, go to the Remote tab, click the Check For Update button, then click Perform System Update. Name: RAIDiator-x86 Version: 4.2.28 Date: Mon Jun 22 12:31:19 2015 Size: 57227264 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Send me your logs and I can check.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to, trying tofigure things out... the admin page wasn't loading until just now and it says connecting to the readynas admin page very very slowly.....
Not sure it will even show up.
Am I supposed to force shut it down? Put back my single test disk and get the logs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
like the box itself still says booting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have sent you a PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well after all that, huge kudo's to Netgear for supporting legacy! The new RN526x is humming along wtih my old pro pioneer drives and old data patiently waiting it's new set of drives when they arrive! It's great to feel justified in sticking with ReadyNAS in blind faith all these years and find out it pays off! I can access my stuff!
Thanks again!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great to hear!
Your Pro Pioneer had a good run. The new models (e.g. your RN526X) certainly are a big jump forward from that.
