Orbi WiFi 7 RBE973
Reply
ReadyNAS Pro rebooting and resyncing, with file copy hangups and other issues
Ear-Relevant
Re: ReadyNAS Pro rebooting and resyncing, with file copy hangups and other issues
Sandshark,
Thanks for your comments and support in this thread!
Yes, I got the OEM Seasonic from Newegg, and it has the two wire sets with 2 4-pin Molex and one Floppy connector.
I used both 4-pin Molex from one wire set, and one from the other set.
I may eventually use one of the original 90 degree Molex connectors, with the slip-off cap over the easy push-in wire connections, to modify the floppy connector. This would giving one wire set per 2-disk connector in the NAS like the original setup.  As I pondered in my previous post, I wonder if it is actually necessary in terms of power distribution.   Like you, I suspect they are all internally on a common rail, so why bother with the modification?   I think those PSU power wires can handle a ~50w load.
With today's large drives, if the rest of the NAS keeps running smoothly, the loss of a single drive bay is not a problem.
Message 26 of 26
Top Contributors
Discussion stats
  • 25 replies
  • 16973 views
  • 5 kudos
  • 4 in conversation
Announcements
