× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS RN2120v2 OS 6.10.6 freezes
Vensdale
I installed recent OS v6.10.6, made a Factory Reset, made a RAID 10 with the brand new 4xWD Ultrastar DC HC320 8TB and started to copy my files to RN2120v2 using Windows 10 PC. The problem is it sometimes freezes during file copy. Only switch on the back of the unit can bring the NAS back online. After second freeze NAS started resyncing. Antivirus, filesearch, snapshots are turned off. Only SMB and SSH protocols are switched on. Only 1 app is installed - SMB Plus. HDDs SMART shows no errors. What can cause the freezes? I can share the logs taken right after reboot (after second freeze).
/dev/md0 3.7G 491M 3.0G 14%
Model: RN2120v2|Readynas 2120v2 1U 4-Bay Diskless
Message 1 of 11
Guru
Re: ReadyNAS RN2120v2 OS 6.10.6 freezes
This is the root (OS) partition, and it has plenty of free space - so not the issue here.
Despite the healthy SMART stats, this appears to be disk related.  Have you looked in system.log, systemd-journal.log and kernel.log for disk or btrfs errors?
Message 2 of 11
Vensdale
StephenB, thank you for your answer! Here are some excerpts from the mentioned logs just before the manual Reboot.
system.log
Spoiler
Jan 29 02:17:01 VENAS CRON[5454]: pam_unix(cron:session): session closed for user root
Jan 29 02:31:15 VENAS connmand[2238]: ntp: adjust (slew): -0.015400 sec
Jan 29 02:48:20 VENAS connmand[2238]: ntp: adjust (slew): +0.025409 sec
Jan 29 03:05:25 VENAS connmand[2238]: ntp: adjust (slew): -0.025897 sec
Jan 29 03:15:07 VENAS dbus[2236]: [system] Activating service name='org.opensuse.Snapper' (using servicehelper)
Jan 29 03:15:07 VENAS dbus[2236]: [system] Successfully activated service 'org.opensuse.Snapper'
Jan 29 03:17:01 VENAS CRON[5953]: pam_unix(cron:session): session opened for user root by (uid=0)
Jan 29 03:17:01 VENAS CRON[5954]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 29 03:17:01 VENAS CRON[5953]: pam_unix(cron:session): session closed for user root
Jan 29 03:22:29 VENAS connmand[2238]: ntp: adjust (slew): +0.008501 sec
-- Reboot --
Jan 29 15:45:25 VENAS dbus[2182]: [system] Successfully activated service 'org.freedesktop.systemd1'
systemd-journal.log
Spoiler
Jan 29 02:17:01 VENAS CRON[5454]: pam_unix(cron:session): session opened for user root by (uid=0)
Jan 29 02:17:01 VENAS CRON[5455]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 29 02:25:04 VENAS systemd[1]: systemd-journald-audit.socket: Cannot add dependency job, ignoring: Unit systemd-journald-audit.socket is masked.
Jan 29 02:25:04 VENAS systemd[1]: Started Radar Update.
-- Reboot --
Jan 29 15:45:13 VENAS systemd-journald[1056]: Runtime journal (/run/log/journal/) is 8.0M, max 100.8M, 92.8M free.
Jan 29 15:45:13 VENAS systemd-journald[1056]: System journal (/var/log/journal/) is 8.0M, max 50.0M, 41.9M free.
kernel.log
Spoiler
Jan 28 22:14:09 VENAS kernel: mvneta d0070000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Jan 28 22:14:09 VENAS kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
-- Reboot --
Jan 29 15:45:14 VENAS kernel: Booting Linux on physical CPU 0x0
Jan 29 15:45:14 VENAS kernel: Initializing cgroup subsys cpuset
Can't find any btrfs or disk related errors (
Currently I started a disk test. It's still going...
Message 3 of 11
Guru
This is a bit unusual, as normally I'd expect to see gigabit ethernet.  Are you using a fast ethernet switch?
Message 4 of 11
Vensdale
RN2120's LAN1 was connected to a Mobile Router. It's 100Mbps. But LAN2 was connected directly to a Windows PC 1Gbps LAN port. Files were copied over LAN2.
Message 5 of 11
Vensdale
Disk test didn't find any problems with HDDs ((
Message 6 of 11
Guru
When it freezes, can you reach the NAS over LAN1?  (starting with ping).
Message 7 of 11
Vensdale
Yes, I tried to ping NAS during freeze from both LANs. No luck(
Message 8 of 11
Guru
Is the fault LED lit when it freezes?
Also, are you comfortable enabling ssh?
Message 9 of 11
Vensdale
StephenB, sorry for looong delay! I had to find 4 cheap HDDs to experiment with RN2120v2 because I don't want to stress my brand new WD HC320s with hard reboots. I got 4 1TB Seagates and that took some time. Made a new connection using Gigabit Ethernet Switch D-Link DGS-1100-16V2. Made a new RAID. But the problem is still there. RN2120v2 is still freezes during file copy operation. I can clearly say when it freezes it doesn't respond to ping, you can't reach it over SSH, the fault led is turned off, the lan led is lit and blinks when you try to ping RN2120v2. I'm comfortable with SSH but don't know much commands. In case you can write needed commands I'll gladly experiment with my RN2120v2. As far as I can tell it freezes only during file copy operations. HDDs were replaced so I don't think they cause the issue.
Message 10 of 11
Guru
What disks did you purchase?  SMR drives can create problems with RAID and BTRFS.  There is a CMR/SMR list here: https://www.seagate.com/internal-hard-drives/cmr-smr-list/
If you have both LANs connected, try connecting only LAN 1, and see if you still have the problem.  If that continues to fail, try the same test using LAN 2.
Not sure where to go next if these tests both fail.  Maybe create 4 jbod volumes using the test disks, and try the test on each volume separately.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1425 views
  • 0 kudos
  • 2 in conversation
Announcements
