- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS RN3xx Performance Issues (145 Mbps instead of 500 Mbps)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Had a performance issue with my ReadyNAS where just reading files was slow. Turned off SMB encryption then immediately re-tested and it made no difference.
Turns out for encryption settings to apply after changing them (at least on a per-share basis and in 6.9.4 hotfix 1) you need to either:
- Disable/re-enable SMB or
- Fully reboot the NAS
"Desired" or "Required" both lead to encryption being enabled on a Windows 10 client and therefore a performance drop, "Enabled" is the only per-share setting to work without it on Windows 10 clients.
The RN3xx series gets around 144 / 145 Mbps of throughput when encryption is in use and 509+ Mbps when not.
Performance all great again! 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS RN3xx Performance Issues (145 Mbps instead of 500 Mbps)
500 mbps (~62 MB/s) still seems slow to me. You should be getting around 100 MB/s for reads/writes of large sequential files over a wired gigabit network. How are you testing this? Is AV enabled on the NAS?
Newer NAS (RN 42x, RN52x, etc) have hardware support for SMB transport encryption, the RN3xx doesn't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote: "You should be getting around 100 MB/s for reads/writes of large sequential files over a wired gigabit network."
Can confirm read/write performance (unecrypted) on my wired gigabit network:
RN426 - 110MB/s (RAID6)
RN202 - 100MB/s (RAID5)
even my RN104 is getting 70MB/s (RAID0 and RAID1)
- Mark as New
- Bookmark
- Subscribe
- Permalink
They're Western Digital RED drives so the 52,000 RPM might be limiting it.. along with the Asus RT-AC68U (in "media bridge" mode, looking to get that replaced in future possibly with a MIkrotik) and probably the Realtek Gigabit NIC with offloading enabled isn't helping... also the CAT6 cable is running along the power brick and next to a UPS.. could fiddle with the setup some more to get more throughput but mainly just pleased I'm not having access being 3 times slower.
Using hashcheck to generate hashes so the file is just being read and not stored (didn't want the disk drive of the device I'm copying to to be a factor)
The speeds also increased a bit more after performing a defrag.
No AV, No file search (I saw the RN316 have connection stability issues with that, separate post 🙂 )
Interesting the newer models do hardware offloading of the encryption, probably another thing to list to my thread on the differences between RN3xx vs RN4xx :).
RAID5/6 might be a bad comparison for performance as it'll use the stripe to retrieve the file. This is just a RN312 with RAID1.
Might also be bitrot detection that means I won't get the full 100MB/s... but 70MB/s (after defrag) is close enough :). 18MB/s was painful (my Internet connection was faster)!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@matthew1471 wrote:
They're Western Digital RED drives so the 5200 RPM might be limiting it
No. I use WDC Reds, and I see much faster speeds on my RN500 series NAS ( using 10 gig ethernet), and 100 MB/sec in my older Pro-6.
That might be the limiting factor then. You could try using NAStester ( http://www.808.dk/?code-csharp-nas-performance ), and set the target to the NAS share.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using Windows 10 clients that negotiate SMB_3.1 and the ReadyNAS logs state it is doing signing.. in SMB 3.1 they upped the strength of the signing algorithm to something less favourable for embedded hardware (AES-128-CMAC in SMB 3 from SMB 2's HMAC-SHA256 and from SMB 1's MD5*). I suspect there might be a performance drop with SMB 3 clients if the client even proposes the NAS signing?
Much happier the performance has gone up by nearly 4 times though by changing the encryption on that share to just "Enabled" and rebooting! So not a large dealbreaker if I can't eek out that final 30% performance increase.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check the advanced SMB settings for the share, and see if "strict sync" is enabled. Turning that off can give you a big speed in some situations.
