× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Ultra 2 - Forgotten admin pass, OS-reinstalled, only Shares and Password visible
Qn1f3
Hi,
I have an ReadyNAS Ultra 2 which has been stowed away during a move. Now when I start it up it refuses to let me log in to the NAS, I can only see "Shares" and "Password" tabs and it refuses to let me login with my prior credentials. So I performed an OS reinstall, but exactly the same phenomena appears.
Any help in the matter would be greatly appreciated?
/Qn
Model: ReadyNAS RNDU2000|ReadyNAS Ultra 2 Chassis only
Message 1 of 9
msq
Apprentice
Apprentice
Re: ReadyNAS Ultra 2 - Forgotten admin pass, OS-reinstalled, only Shares and Password visible
Have you tried to use default credentials after OS reinstall ..?
Message 2 of 9
bedlam1
Prodigy
Have you tried to login as
User: admin
Password: netgear1
Also what is Raidar finding?
Message 3 of 9
Qn1f3
Yes, more elaborate answer on next tip.
Message 4 of 9
Qn1f3
I did with what I thougt was the default credential, which are not the ones you provided.
In together with Raidar this gave me control over my data again(thanks), now I have other issues to take care of though. Implementing a correct configuration for NTFS that suits my needs since this NAS only has support for SMB1 it seems, and also getting a new drive(one of them are generating more and more errors).
Thanks a lot for the quick help and replies!
Message 5 of 9
Sandshark
Sensei
IMHO, your best bet in getting past the configuration issue is to consider moving to OS6.  It is unsupported by Netgear on legacy hardware, but does work on your Ultra and you can find instructions on how to install it here in the forum.  It does require a factory defult, so you need to back up and restore your data.
Message 6 of 9
Qn1f3
I will be sure to take that into consideration, this will probably be an interim sollution hence my external power brick has started emitting coil whine. So I believe the life expectancy is highly restricted, unless it's possible to find replacements parts for these legacy models?
Message 7 of 9
Sandshark
Sensei
The external power supply is easily replaced.  The rest, no.  It's a 12V 5A supply with a standard connector on it.  I recommend you go with a supply rated for security cameras rather than LED lighting, as they tend to have better regulation.
Message 8 of 9
Guru
The default admin password for the ultra (running 4.2.x firmware) is netgear1.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 2317 views
  • 0 kudos
  • 5 in conversation
Announcements
