Orbi WiFi 7 RBE973
Reply
ReadyNAS Ultra 4 - ffmpeg corrupted ?
Max_1968
Hi,
I've done quite some modifications to my Ultra, and also had ffmpeg running fine for quite some time. However I had to "remove" this together with the dependencies lately and now wanted to install it again, but it fails:
ReadyNAS:~# apt-get install ffmpeg
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
libavcodec52 libavdevice52 libavformat52 libavutil50
The following NEW packages will be installed:
ffmpeg libavcodec52 libavdevice52 libavformat52 libavutil50
0 upgraded, 5 newly installed, 0 to remove and 2 not upgraded.
Need to get 1192kB of archives.
After this operation, 3658kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://www.readynas.com 4.2.26/ libavutil50 4:0.6.7-0.netgear1 [80.5kB]
Get:2 http://www.readynas.com 4.2.26/ libavcodec52 4:0.6.7-0.netgear1 [679kB]
Get:3 http://www.readynas.com 4.2.26/ libavdevice52 4:0.6.7-0.netgear1 [43.1kB]
Get:4 http://www.readynas.com 4.2.26/ libavformat52 4:0.6.7-0.netgear1 [253kB]
Get:5 http://www.readynas.com 4.2.26/ ffmpeg 4:0.6.7-0.netgear1 [136kB]
Fetched 1124kB in 4s (271kB/s)
Failed to fetch http://www.readynas.com/packages/4.2.26/f/ffmpeg/libavutil50_0.6.7-0.netgear1_i386.deb Size mismatch
Failed to fetch http://www.readynas.com/packages/4.2.26/f/ffmpeg/libavcodec52_0.6.7-0.netgear1_i386.deb Size mismatch
Failed to fetch http://www.readynas.com/packages/4.2.26/f/ffmpeg/libavdevice52_0.6.7-0.netgear1_i386.deb Size mismatch
Failed to fetch http://www.readynas.com/packages/4.2.26/f/ffmpeg/libavformat52_0.6.7-0.netgear1_i386.deb Size mismatch
Failed to fetch http://www.readynas.com/packages/4.2.26/f/ffmpeg/ffmpeg_0.6.7-0.netgear1_i386.deb Size mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
ReadyNAS:~#
To me it seems the archives on the Netgear server are corrupted, or am I wrong ?
apt-get update and --fix-missing don't work either:
ReadyNAS:~# apt-get update
Ign http://repository-openhab.forge.cloudbees.com Release.gpg
Ign http://repository-openhab.forge.cloudbees.com Translation-en_US
Hit http://repository-openhab.forge.cloudbees.com Release
Hit http://www.readynas.com 4.2.26/ Release.gpg
Ign http://www.readynas.com 4.2.26/ Translation-en_US
Ign http://repository-openhab.forge.cloudbees.com Packages/DiffIndex
Hit http://repository-openhab.forge.cloudbees.com Packages
Ign http://www.readynas.com 4.2.26/ Packages/DiffIndex
Hit http://www.readynas.com 4.2.26/ Packages
ReadyNAS:~#
ReadyNAS:~# apt-get --fix-missing ffmpeg
E: Invalid operation ffmpeg
ReadyNAS:~# apt-get --fix-missing install ffmpeg
Fetched 1124kB in 4s (265kB/s)
ReadyNAS:~#
Thx,
Max
Message 1 of 2
RezzZ
Tutor
Re: ReadyNAS Ultra 4 - ffmpeg corrupted ?
I have the exact same issue.
I need this to install package dialog but keep walking to this wall of size mismatches for ffmpeg...
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1513 views
  • 0 kudos
  • 2 in conversation
Announcements
