- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Ultra 4 interfering with network traffic
- Mark as New
- Bookmark
- Subscribe
- Permalink
Starting a few days ago, my ReadyNAS Ultra 4 running RAIDiator 4.2.28 is somehow interefering with network traffic on my home network. When I have the NAS disconnected from my router, all of my other connected devices are able to access the Internet without issue. However, when the NAS is on my network, I am experiencing periodic web blockage on all other devices. Connections can be exorbitantly slow, almost like I am having DNS issues, but my DNS servers are fine (provided by ISP and using DHCP).
It's an intermittent problem. Sometimes while the NAS is on, everything is fine for a short period, but then it will again periodically block traffic after a few minutes.
I've disabled almost all services on the NAS. I only left CIFS, AFP, and ReadyDLNA running (as I've done for the past 5+ years).
Anyone have any ideas how or why it could be blocking traffic?
Here's a traceroute from my Mac during one such time:
traceroute to www.google.com (195.249.23.153), 64 hops max, 52 byte packets 1 192.168.1.1 (192.168.1.1) 1.036 ms 0.576 ms 0.585 ms 2 lo0.br1-alb.ip.fullrate.dk (90.185.1.166) 20.989 ms 30.328 ms 23.832 ms 3 90.185.1.208 (90.185.1.208) 29.378 ms 30.111 ms 34.992 ms 4 188.180.106.9 (188.180.106.9) 28.676 ms 176.22.75.157 (176.22.75.157) 32.927 ms 34.316 ms 5 83.88.19.143 (83.88.19.143) 33.492 ms 34.181 ms 29.842 ms 6 * * * 7 * * * 8 * * * 9 * * * 10 * * * 11 * * * 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 * * * 23 * * * 24 * * * 25 * * * 26 * * * 27 * * * 28 * * * 29 * * * 30 * * * 31 * * * 32 * * * 33 * * * 34 * * * 35 * * * 36 * * * 37 * * * 38 * * * 39 * * * 40 * * * 41 * * * 42 * * * 43 * * * 44 * * * 45 * * * 46 * * * 47 * * * 48 * * * 49 * * * 50 * * * 51 * * * 52 * * * 53 * * * 54 * * * 55 * * * 56 * * * 57 * * * 58 * * * 59 * * * 60 * * * 61 * * * 62 * * * 63 * * * 64 * * *
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Ultra 4 interfering with network traffic
It can't block traffic, but it could create interfering traffic (either on the local LAN or on the internet connection).
Do you have ports forwarded to the NAS in the router?
You could try blocking internet services to the nas in your router, and see if the problem disappears.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't have any port forwarding set up on the router at all. What kind of Internet services could I potentially block on the NAS? How is this typically configured on a router, from a high-level standpoint?
- Mark as New
- Bookmark
- Subscribe
- Permalink
With most Netgear routers there is a "block services" screen in the advanced settings UI.
You can block any port range you want from reaching the ReadyNAS, and there is a built-in service for "all".
Also - are you connecting only one of the two ethernet ports? Or are both connected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a ZyXEL VMG8924-B10A router, provided by my ISP. I'm only using one ethernet port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should be able to do this from the parental control screens - page 207 and following here: https://www.zyxel.com/za/en/uploads/images/VMG8924-B30A_V1.00-UG.pdf
The user would be custom, and then set to the mac address of the ultra. You'd add a service that uses the full port range (1-65535) for UDP and TCP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I got the parental control restrictions set up properly I believe. So far, so good. What does this effectively mean for the ReadyNAS though? Will the automated backups I have through Vault stop working now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Outbound services like vault, readynas update request, ntp time sync should all be blocked
If blocking the internet service solves the network traffic problem, then the next step is to try unblocking the service, and see if the problem returns.
If it does, then there needs to be some deeper analysis on what's happening - checking to see if the NAS is hacked, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, after a long delay and lots of testing, it looks like blocking the services solved the networking problems on other PC's and devices on our LAN. So, what's the next step?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's hard to say, since we really don't know what the NAS is doing to destabilize your network.
One option is to try shutting down the NAS and removing the disks (labeling by slot). Then insert a scratch disk (not part of the array) and do a factory install. Configure the NAS network services similarly to your current setup. Then unblock the internet services, and see if the problem still occurs.
If the issue stops, then that suggests doing a factory reset, rebuilding the NAS, and restoring the data from backup. Painful and brute-force to be sure, but this problem has been dragging on for quite some time now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I'm thinking of upgrading to a newer ReadyNAS instead of doing a reinstall, what would be a reasonable newer functional analog to the Ultra 4?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see other forum threads referencing similar symptoms, where DNS seems to be blocked or delayed. But the Ultra 4 doesn't have firewall configuration options as mentioned in these threads.
https://community.netgear.com/t5/Managed-Switches/FVS336Gv2-DNS-Issues/td-p/1058861
Is there potentially a known issue that could block DNS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, those posts are for very different products. I don't think they apply to your case. The NAS doesn't proxy DNS, and shouldn't interfere with DNS lookups from other devices.
I'm wondering if somehow your NAS was hacked somewhere along the way.
The RN424 is the closest of the new models.
There's an older RN314 that is being phased out - you could get that one if you see a good price. Performance is similar to the ultra, and I don't forsee any support challenges with the older product.
If you do switch, you can do a full factory reset on the ultra, which I think will resolve your issue. Then you can use it as a backup NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think at this point that the device hasn't been hacked. I can see that when ReadyNAS Vault is enabled, it immediately causes DNS/timeout errors on other devices on my LAN. I have a very slow upload speed via DSL (2 Mbps), and I think Vault is just oversaturating my network. I've configured Vault to run at a trickle during the day, and at max during the night, and it seems OK so far.
