× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Ultra 6 (6.10.10) doesn't boot - Stuck on "ReadyNAS" prompt screen
ItsPeter2
Guide
I think my unit has finally died, I'm just trying to confirm, or see if there's a way to work out which component is faulty.
Power on, shows "ReadyNAS" on the front panel, goes no further. I can't hear it powering up any disks. If I pull all the disks and power on, I don't get any "no disk" error. If I hold in "reset" and power on, I don't get any boot menu. If I hold down "backup" and power on, it doesn't attempt to boot from USB. Anything I've missed trying?
Unit was upgraded to OS6 about 4.5 years ago, 4GB RAM installed, I don't think that's the issue. Original power supply wore out about 6 months ago and I replaced it, seems unlikely the new one has failed (old one stopped generating enough power to kick over and start the unit, unit seems to power on fine, just not booting).
I'm guessing I'm looking at failure of CPU, mainboard or similar - anything else I can do to diagnose? Probably not worth spending $$$ on at this stage (better spent on something new), the unit is quite old - lasted probably longer than expected.
Message 1 of 7
Guru
Re: ReadyNAS Ultra 6 (6.10.10) doesn't boot - Stuck on "ReadyNAS" prompt screen
This is usually a failed PSU.  You can replace it fairly inexpensively.  I'm tagging @Sandshark as he often provides useful advice on this..
Message 2 of 7
ItsPeter2
Guide
I'm not saying it's impossible that the PSU has gone bad, but I installed a brand new Silverstone SX700-G power supply into the unit in April - that power supply would still be under warranty.
https://cplonline.com.au/silverstone-sst-sx700-g-700w-sfx-power-supply-80-plus-gold-fully-modular.ht...
I think my only way to test this would be to buy another PSU - happy to give it a shot, it just seemed unlikely to get a fail on a basically already new PSU.
Message 3 of 7
Guru
Only seeing ReadyNAS on the LCD screen suggests that the PSU might only be delivering 5 volts.
Message 4 of 7
Sandshark
Sensei
There are actually a lot of things that can cause this, the PSU is just the most common.  "ReadyNAS" is the default display, programmed into the display itself, so it only takes 5V for it to show up.  The NAS doesn't even need to get through POST, so RAM, CPU, and a lot of other components could be the culprit.
Rather than purchase yet another supply, do you have a standard ATX12V supply (even one you can temporarily remove from a computer)?  You can hook it up externally and see if the NAS boots.
Message 5 of 7
ItsPeter2
Guide
Thanks - there is likely a PC here with a compatible supply, we'll pull some things apart and see what tests we can run.
Message 6 of 7
ItsPeter2
Guide
Powered the unit up on a Corsair CV550 ATX power supply, no change.
I dug out the original 1GB RAM for the unit and swapped that back in, no change with that either.
I don't think there's much else can be tried, seems like it is indeed dead. Thanks for the suggestions, it was worth a shot.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 676 views
  • 2 kudos
  • 3 in conversation
Announcements
