- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
ReadyNAS Ultra 6 Review (RNDU6000) no network activity???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Ultra 6 Review (RNDU6000) no network activity???
I did what is in the manual. Via putty with telnet but no connection.
I tried to boot the NAS again but it is not booting any more. So, I dont know what happend??? Only seeing READY NAS. And RAIDar can not find the NAS either. Even without disks it is not booting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sadly, this is sounding more and more like a hardware issue and you just got lucky when it booted a few times. Are you back to seeing no Ethernet activity? Try turning it off for an extended period and re-boot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No network activity indeed. Could it be that the NAS is initializing the disks some how? Or because off the 2 new memory banks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you ever get it to boot past "ReadyNAS" on the display with the new memory? If not, it could be either the memory itself or something that came loose when you added it. It's not the drives initializing. Even though access can be a bit slow, your NAS is still accessible during volume initialization.
- Mark as New
- Bookmark
- Subscribe
- Permalink
With the new memory banks it was just working fine. Boot a several times and it was accessible. After trying to get in support tech modus it was till working fine. Just when I was to try again and check Putty is via telnet and not SSH, I pushed twice for shutting down. After that is was not booting again. I tried also with the old memory bank but still the same. Not booting, no internet led`s and not accessible. So it is not booting. With disks or without disks. With new memory or old memory.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And the display just says "ReadyNAS"? Could be flash memory corruption, for which a USB recovery is the solution. Did you successfully back up the VPD file? Since USB recovery re-writes the flash where the VPD is located, corruption of it is possible (though it's supposed to be protected).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, only READYNAS and fans full blowing. And green led above backp button on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The display will show "ReadyNAS" with nothing present except 5V, so there are many possibilities.
Sounds like time to try USB recovery. You never got to the point of installing OS6, right? So, a standard OS4.2.31 recovery is called for. It could be the power supply or something else (lots of re-booting can stress an old PSU and other components). If the USB recovery doesn't work, then further investigation is best performed by first installing a VGA cable and monitor onto the VGA header located on the motherboard and seeing if it's even getting through motherboard POST.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Never installed OS6. https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool never worked so far. I follow the rules and create a usb but it is not comming in recovery modus or any modus.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Legacy units are very picky about the USB drive you use, so you should try a couple more if you have them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing happend. I tried 10 different usb sticks. I think it is realy dead this time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looking back through the thread, it does not appear you ever properly tried another power supply. A failing PSU was was one of my early suspicions. I've never tried to connect just the 24-pin connector, as you apparently did, I think you must also power the SATA backplane. I absolutely know that you cannot leave the original PSU connected to the backplane and expect it to work with a different supply on the 24-pin. If the ATX power supply you tried has no 4-pin Molex connectors, then you'll need some SATA to Molex adapters. With no drives installed, just for testing, you should only need to connect one of the three.
Then again, with your data now all backed up, you may want to take this as a sign it's time to move on to another NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I already have another NAS. I have this one:
QNAP TS-h973AX, 32GB ram, Seagate IronWolf Pro schijven, 30TB
I have tried another powersupply but I can try again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It took some time but I tried with another powersupply and it is the same. It is not booting at all. With or without disks. Anyone another tip?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay thank you all a lot for helping me out. The NAS is dead. So I will try to sell the memory banks en use the HD for extra back-up storage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
You should not "tack on" to other message chains, especially those with different symptoms from yours. Is your NAS also an RNDU6000? How have you reached the conclusion your VPD is corrupt?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see now you asked this in two different threads. I will not respond to follow-on messages in this one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- Next »
