- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Ultra6 system temp warnings every 15 minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Ultra6 keeps emailing me about system temperature alerts.. at ~25 degrees celcius. So basically room temperature. I've been messing about with the sensors configuration, but for some reason I cannot seem to get the desired results. I would appreciate any help with the sensors problem, and with fancontrol.
The system is operating on ReadyNAS OS v6.10.2.
The problem sits in the min/max temps. Here is my sensors output:
System: 1054 RPM (min = 399 RPM) System: +28.0°C (low = +28.0°C, high = +28.0°C) ALARM sensor = thermal diode
Due to the low and high being set to the current temp, it's in a constant alert state.
And my /etc/sensors.d/system.conf
root@MueR-NAS:~# cat /etc/sensors.d/system.conf chip "coretemp-isa-0000" label temp2 "CPU" compute temp2 @%35, @%35 ignore temp3 chip "it8721-isa-*" ignore in0 label in0 "V+12" compute in0 @*4, @/4 set in0_min 10.8 set in0_max 13.2 label in1 "V5_0" compute in1 @*1.68, @/1.68 set in1_min 4.7 set in1_max 5.3 label in2 "V3_3" compute in2 @*1.649, @/1.649 set in2_min 3.135 set in2_max 3.465 ignore in3 label in4 "V1_2" set in4_min 1 set in4_max 1.3 ignore in4 label in5 "V1_8" set in5_min 1.5 set in5_max 2.1 label in6 "V-12" compute in6 @*19-50.4, (@+50.4)/19 set in6_min -13.2 set in6_max -10.8 set in7_min 3.135 set in7_max 3.465 ignore fan1 ignore fan2 label fan3 "System" set fan3_min 400 ignore temp1 label temp2 "System" set temp2_min 1 set temp2_max 80 ignore temp3 ignore intrusion0
I've reloaded the sensors configuration several times to no avail. Does anyone have a working RNDU6000 sensors system config that doesn't spam to death about the system temp?
On a related note, due to the constant alarm state of the system temp, fancontrol is all over the place. Spins up, then 5 seconds later spins down again. Really annoying to say the least. While I'm pretty sure that this problem might fix itself once the temperature issue is solved, if someone does have a working Ultra6 fancontrol config, I would appreciate it.
Thanks in advance for any pointers!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Ultra6 system temp warnings every 15 minutes
What is the history here? Did it begin misbehaving when you converted to OS6, or is this new since an OS update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah yes, sorry, I forgot to add that. It started misbehaving when I updated from 6.9. I do recall having had this problem with an earlier version of OS6, but can't recall how I fixed that as that was roughly when OS6 became available for the Ultra6. It's just weird that the system apparently chooses to ignore min/max temperature settings as configured.
