× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS alert: Volume Warning - looks like a full root volume
btsixer
I'm receiving ReadyNAS warnings stating:
Less than 30% of volume media's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection snapshots will be deleted when volume free space is less than 5%.
In looking at the following solved topic, I'm sure it is the root volume that is full based on my btrfs.log
https://community.netgear.com/t5/Using-your-ReadyNAS/Volume-Warning-on-Disk-Useage/m-p/1149985#M1171...
My question is what I do to resolve the capacity issue. How do I fix?
I have a ReadyNAS516 running the newest firmware v6.6.1
Thanks.
Blaine
Message 1 of 8
vandermerwe
Master
Re: ReadyNAS alert: Volume Warning - looks like a full root volume
The message is referring to the data volume.
How much of the volume capacity are you using?
Are there any apps installed?
If it is a similar problem it'll probably require remote access.
Message 2 of 8
mdgm-ntgr
NETGEAR Employee Retired
If btsizer has checked btrfs.log and the data volume is less than 70% full then it could well be the root volume.
If it is the root volume it can be fixed using SSH. It's a matter of determining what's using lots of space of the root volume and then dealing with it appropriately.
Message 3 of 8
btsixer
Howdy, details from btrfs.log and screenshots showing volume use attached.
BTRFS.LOG
Label: '43f664ec:root' uuid: ***
Total devices 1 FS bytes used 2.98GiB
devid 1 size 4.00GiB used 4.00GiB path /dev/md0
Label: '43f664ec:data' uuid: ***
Total devices 2 FS bytes used 6.76TiB
devid 1 size 4.53TiB used 4.29TiB path /dev/md127
devid 2 size 9.10TiB used 2.91TiB path /dev/md126
VOLUME CAPACITY
READYNAS ALERT
Message 4 of 8
mdgm-ntgr
That's very conclusive. You're using close to 3GB of the 4GB capacity of the root volume
Message 5 of 8
Guru
Plus the first data volume is also very full.
So there are two things to take care of.
Message 6 of 8
btsixer
Is there a utility I can run that allows me to care for disk utilization? Should I be attempting something along the lines of balancing data volumes?
I can do some searches for command line root cleanup but anything you can suggest would be helpful to get me started.
Thanks.
Message 7 of 8
btsixer
Just found this KB:
https://kb.netgear.com/26941/ReadyNAS-OS-6-An-overview-of-relevant-scheduled-maintenance-tasks-avail...
Scrubbing
Defrag
Balancing
I'm going to back up the entire NAS and then take the storage offline and go through the process of cleaning everything up.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4214 views
  • 0 kudos
  • 4 in conversation
Announcements
