Orbi WiFi 7 RBE973
Reply
ReadyNAS netgear rn10400 error -out of memory+36c
alexnts
Hi.
We keep getting an error -out of memory+36c a minute after the NAS boots up when not in read-only mode.
Please help.
Model: RN10400|ReadyNAS 100 Series 4-Bay (Diskless)
Message 1 of 7
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS netgear rn10400 error -out of memory+36c
Which firmware are you running?
If running 6.7.0 or later and if you have quotas enabled on the volume please try an OS Re-install.
Message 2 of 7
alexnts
Thanks a lot for a swift answer.
I'm running 6.6.1 and no quotas.
We use the NAS as a location for backups via Bacula system and for storing some installation files.
I seem to be unable to update too because it runs in volume read-only mode now and fails with the error immediately if returned to normal boot... 😞
Message 3 of 7
mdgm-ntgr
Unless you disabled them from the backend quotas would be enabled on the volume. The GUI option to disable quotas on the volume wasn't added till 6.7.0.
You could power down, remove your disks (label order), put a scratch disk in (must not be from your array), update the firmware, verify the update was successful, power down, put your disks back in and do an OS Re-install.
Message 4 of 7
alexnts
Sadly we don't have any replacement disks 😞
Also I wasn't the one who did the initial configuration.
I there any possibility to do it without additional disks?
Will the OS Reinstall delete all the settings?
Message 5 of 7
Guru
The scratch disk can be any SATA disk you happen to have around (and can be any size).  You will need one to do the first step @mdgm-ntgr recommends
Note the part where you upgrade the firmware with the scratch disk installed (if necessary) - that is actually a pretty important aspect.
No.  It turns off quotas,  and resets the network configuration to use DHCP.  It also will reset your admin password to password.
Other settings shouldn't be changed.
Message 6 of 7
alexnts
Thanks a lot.
We'll try it on Sunday and reply back.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2868 views
  • 0 kudos
  • 3 in conversation
Announcements
