- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS os failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS os failure
Hi,
I have a ReadyNAS 516 and it is unable to boot properly with a currupt OS.
I tried an OS Reinstall but that stalls at checking fs.
Cannot SSH or anything, I also tried downloading and using the USB os install but it won't boot into that either.
Does anyone else have any idea's?
RAIDar reports management service offline. I also cannot get the logs.
What would happen if I removed all disks, then did a factory reset and then put all the disks back in in the same order, will I be able to access the data?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS os failure
Hi realtek1,
Can you check if the logs can be extracted using the RAIDar 6.0? Also, have you contacted our support team about this?
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
USB Boot Recovery will only help if the firmware on the flash is corrupt. This clearly is not the problem here. So USB Boot Recovery won't help.
Not all USB keys are compatible and if the unit was one of the early 516 units it can take a few goes to get the timing right to do USB Boot Recovery.
@realtek1 wrote:
Hi,
So it sounds like problem is on the root volume on the disks.
Considering the whole purpose of a factory reset is to wipe the disks and do a clean install of the OS and create a fresh volume, what you propose won't help at all.
I would follow BrianL's advice. Contact support.
