× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS pro 6, random halt after 6.9.0
WingDog
Guide
Hello.
After FW upgrade to 6.9.0 one of the Pro6 boxes started to halting at random time. No ping, no web interface, no iSCSI, no SMB.
upgrading to 6.9.3 didn't help.
how to fix it? thanks.
Model: RNDP6610-200|ReadyNAS® Pro 6
Message 1 of 19
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS pro 6, random halt after 6.9.0
Are you running any other services?
Are you using any apps?
Can you send me your logs (see the Sending Logs link in my sig)?
Message 2 of 19
Retired_Member
Not applicable
At the given times it might be totally overwhelmed by dealing with the antivirus service. If not already done, you might want to disable this and see whether it helps.
Another resource hog is is the file search service. You might want to try switching this off, too.
Message 3 of 19
WingDog
Guide
I sent log to you.
Search and AV are disabled.
Services are only: http/https/snmp/ssh (it's storage for iSCSI LUN only).
 no any apps installed.
Message 4 of 19
mdgm-ntgr
Your logs are flooded with messages about iSCSI.
How big was the LUN you created? Was it thick/thin?
Is your backup up to date?
Message 5 of 19
WingDog
Guide
LUN is 10Tb (13.6Tb total volume), it's thick and sync writes are allowed.
this is backup LUN 😉
I have no additional backup of this data.
Message 6 of 19
WingDog
Guide
any ideas?
Message 7 of 19
mdgm-ntgr
How much data is on your 10TB LUN?
Message 8 of 19
WingDog
Guide
there is ~5Tb of data.
Message 9 of 19
WingDog
Guide
any updates?
Message 10 of 19
mdgm-ntgr
Does the LUN that kernel.log is full of errors about exist?
Message 11 of 19
WingDog
Guide
there is one LUN, but I don't know what's in the kernel.log
Message 12 of 19
Guru
You could open it and look Smiley Wink
Message 13 of 19
WingDog
Guide
sure 😃
IQN in kernel.log is
Apr 09 07:10:20 nas-repl2 kernel: Unable to locate Target IQN: iqn.1994-11.com.netgear:nas-repl2:01e7a1f3:group1 in Storage Node
but Target name in WebInterface is
iqn.1994-11.com.netgear:nas-repl2:843b3bce:group1
so I suppose this is different LUNs. But I have only one LUN.
Message 14 of 19
Guru
Maybe check the isci initiator on the client?
Message 15 of 19
WingDog
Guide
done.
01e7a1f3 removed from client mapping.
843b3bce connected and is OK.
can it lead to halting the box?
Message 16 of 19
Guru
It shouldn't of course, but perhaps wait to see if the halt happens again, and get a fresh set of logs if it does.
Message 17 of 19
WingDog
Guide
Hi.
NAS halted again.
logs were sent.
Message 18 of 19
WingDog
Guide
any updates?
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 3053 views
  • 0 kudos
  • 4 in conversation
Announcements
