- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS "Admin Page" is offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
HI All,
I have recently purchased ReadyNas 214 after i upgaraded the firmware to 6.6.1 i am unable to get the admin page.
Both the network interface our configured with the same IP.
Now we have changed the network from /16 to /24 and we are unable to open the admin page.
When i connect directly the NAS device to my machoine i can access the Floders from it and also i get the username and password prompt when i open the URL in browser and after that i get the error that the page can not b displayed.
I used Netgear RAIDar it show me all the details but not abe to open the admin page.
Requst you to please assist me in this.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please download the logs using RAIDar 6.2 and send them in (see the Sending Logs link in my sig).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: ReadyNAS "Admin Page" is offline
Did you really configured both network cards? With same settings?
Normally switches don't accept that.
Because with no load balancing / teaming feature no client would know on which interface it should connect.
Load Balancing / teaming and so on doesn't work only if you configure all interface the same way.
It must be configured the "correct" way switch and device are able to communicate against each other.
That would explain why it works, when you connect it directly to your machine (only one link connected).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS "Admin Page" is offline
Hello Sir,
I have send the logs, please check and let me know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you access the NAS if you disconnect one of the ethernet cables?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No sir i can not acces the NAS if i disconnect the cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Team,
Please let me know if anyone body has solution for this.
I am awaiting for the solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Were you able to download the logs with RAIDar?
If not, does the NAS respond to ping?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Boot to volume read-only mode (a boot menu option) and then go to https://ip.address.of.nas/fwbroker and update to 6.7.0. If you still have the problem try an OS Re-install. It should then disable quotas at the volume level.
This change'll stick till you change share settings.
You have a huge amount of metadata on your volume.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am able to download the logs and i have downloaded the logs.
Secondly Nas pings i am able to access the internal folder which are shared.
The problem is i am not able to open the admin page
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you please guide me from where to do this.
Because when i plug the power in its start i dont know how to boot the Firmware with read only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
On NETGEAR RAIDar i am getting error that the management service is offline.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does https://ip.address.of.nas/fwbroker respond? If so, try the 6.7 install that mdgm suggested earlier.
If not, try an OS reinstall and see if that brings the admin page back.
