- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS reports not enough space
- Mark as New
- Bookmark
- Subscribe
- Permalink
My ReadyNAS 524X reports (data shows a red bar) that there is only 481 GB available out of 8.17 TB of space. I have 4 3 TB drives installed in the unit, using RAID 5. I am running on a Mac.
When I use Finder to add up all the folders under "data" on the network, it adds up to only 3 TB. I have rebooted both the Mac and the ReadyNAS.
Any ideas why there is such a discrepancy?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sandshark wrote:On the Volumes page of the GUI, you can see if some of that space is taken up by snapshots and you can also use the gear icon to do a balance. But it would be unusual for a balance to free up that much space.
Thank you for your comments, Sandshark. As a matter of fact, in my case, deleting snapshots and rebalancing did free up that much space. I don't know why it worked, but it did. 🙂
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS reports not enough space
I recently read about rebalancing on the ReadyNAS, which may free up space, but I don't seem to have that option. I have the latest firmware (6.10.2), but Settings does not have an option that I can see for scheduling a rebalance operation.
Anybody have this problem?
@OldTimerGuy wrote:My ReadyNAS 524X reports (data shows a red bar) that there is only 481 GB available out of 8.17 TB of space. I have 4 3 TB drives installed in the unit, using RAID 5. I am running on a Mac.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. I think the first step is to see how much space is in snapshots.
@OldTimerGuy are you using the NAS to store time machine backups?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I am not using the NAS to store Time Machine backups. I use an attached external hard drive. But deleting snapshots and rebalancing worked in my case. Thank you for your comments.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is likely that the snapshot deletion was the main thing that released the free space. Reclaining of free space after deleting snapshots can take a while, and a balance will speed that up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Sandshark wrote:It is likely that the snapshot deletion was the main thing that released the free space. Reclaining of free space after deleting snapshots can take a while, and a balance will speed that up.
Thank you, Sandshark. I will delete the snapshots more often now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you switch to "Custom" snapshots you can explicitly set the retention. I find that to be an easier way to manage the snapshot space than going in and manually deleting the "Smart" snapshots.
If you switch to this, then I suggest starting with 3 months of retention for every share, and monitor the overall snapshot space. Then adjust it to acheive the balance you want.
There is also a setting there to only make snapshots when the main share changes - which I also recommend setting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Great idea StephenB! I'll give it a try.
