- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNASRND2000
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNASRND2000
I have a the ReadyNAS Duo and can no longer "see" the device on the network. The NIC appears to be dead. I've restarted the device, connected to a different switch and have tried different ethernet cables, but get no light on the NIC. What are my options w/the data on the disks?
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
- What firmware are you running?
- Does the NAS say "Duo" on the front chassis? Or does it say "Duo v2"?
You can try connecting disk 1 to a PC, and offload the data with r-linux for windows: https://www.r-studio.com/free-linux-recovery/
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
I believe it's running 4.2.28, since that's the most recent firmware on my desktop and it's a DUO
RND2000-100NAS
v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
RND2000-100NAS
v2
If it's a sparc based Duo
- it will be running 4.1.x firmware (NOT 4.2.x)
- the front chassis will say Duo
If it's an arm based Duo
- it will be running 5.3.x firmware
- the front chassis will say Duo v2
If it's running 4.2.28, then it's either an Ultra-2 or a Pro-2, and not a Duo at all.
The sparc-based Duo is called a v1 here; the arm-based Duo is called a v2 here. I suspect you have a v1 (because of the -100NAS in the part number).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
Apologies for the confusion, it read DUO on the front chassis.
I downloaded R-Linux and attached the drive to a Windows machine, but the only things read are the basic drive properties:
Drive Type - Physical Drive
Name - ASMT 2115 0
OS Object - \\.\PhysicalDrive1
But I'm not able to see anything else...also, this is my first time using R-Linux, so I'm not sure if there are settings that need to be modified.
Thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
Try again with disk 2, and see if that makes any difference. I suggest labeling the disks - it's easy to get them mixed up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
This is what I see with disk2..which is similar to what I saw with disk1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
Hi,
I'm just wondering if I have options with the data on the drives - I can't imagine the information is lost. Any help is greatly appreciated.
Ed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
You should be seeing more drive characteristics in your screen shots.
Did you power the drive when you connected it to the USB adapter?
Do you have another drive model you can use to test the adapter?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNASRND2000
Ed
