× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas 104 stuck booting
pappylapoo
Follower
Hi All,
My readynas 104 is stuck booting at about 60% "Systemd-Update-U" on the LCD display.
I have tried the following:
1. OS-Reinstall
2. Factory Reset
3. USB recovery
4. Changed disks
All with the same result. I can login via telnet in "Tech Support Mode", and was wandering is there is a command that I can force a factory reset. It almost feels its not completely resetting.
I was running 6.9.2 and have updated via USB recovery to 6.9.3, and that didnt help either.
I can see the device in Raidar when is started booting saying "system is starting" but then disapears when it gets further into the boot process.
Thankyou in advanced.
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 1 of 3
Accepted Solutions
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNas 104 stuck booting
This should be fixed now (Successfully completed USB Boot Recovery should have also been able to resolve this).
Also the system time of your system had been set back to 1925 for some reason. That should be fixed as well.
Message 3 of 3
All Replies
mdgm-ntgr
Sounds like you could have had a partially completed update, perhaps with a different firmware loaded onto the disks than the firmware used by the early boot process and the kernel.
Message 2 of 3
mdgm-ntgr
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1310 views
  • 1 kudo
  • 2 in conversation
Announcements
