× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas Duo - Blue Light Blinking & unavailable on network
KevinG1
My ReadyNas duo has been blinking for over two weeks and its just not available on the network.
I tried restarting my ReadyNas Duo multiple times and exactly the same issue. I also tried with different Ethernet cable to ensure that there is no issue with the Ethernet cable.
I then ran Raidar on my pc to Browse ReadyNas Duo and Browse button is greyed out. I cannot also access ReadyNas duo via the IP address and ping also does not work.
I have two hdd and both the lights are showing as GREEN in Raidar and File System Check is 100%.
What could be the issue?? Please assist.
See the image: -->
Thanks
Message 1 of 6
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNas Duo - Blue Light Blinking & unavailable on netw
Could be issues with the filesystem.
Do you have a backup?
Message 2 of 6
Guru
Also, is the NAS IP address on the same subnet as the PC? If you are using private addresses (10.x.x.x or 192.168.x.x) addresses, it is safe to share them, as they are not routable over the internet.
Message 3 of 6
KevinG1
Thanks for the response Stephen... Yes, it is a 192 IP address.
I do not have a backup - but the Raidar System says that file system is 100% and lights are green?
Message 4 of 6
mdgm-ntgr
Perhaps try skipping the volume check: http://kb.netgear.com/app/answers/detail/a_id/21411
Then if it boots up open an online support case and attach your logs zip file (System > Logs > Download all logs).
Support will probably direct you back here, but attaching them there will help to keep track of the issues you've had with your system.
Message 5 of 6
Guru
Is the NAS perhaps 192.168.168.168?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1860 views
  • 0 kudos
  • 3 in conversation
Announcements
