× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas Duo Mk2 Blue light booting forever
2pods
I added a 2gb Drive to the 2gb drive already in (both OK with the list) and it seemed to be expanding OK, but then it needed to boot and has been like that for about 12 hours.
Both drive panel lights are on in blue, but the blue activity light is flickering. Raidar has continued to tell me the unit is booting.
Both hardware and Raidar are up to date.
Help..!
Message 1 of 8
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNas Duo Mk2 Blue light booting forever
Perhaps power off the system, disconnect the power, wait a minute or two, then reconnect the power again and see if it boots.
Message 2 of 8
2pods
Thanks that did it 😄
No I only have to work out how to use it as either a new share, or a redundant drive without losing what I have on the original.
I've tried copying all of "Public" and "Media" to a attached 3tb usb3 drive, but It gives me I/O errors after copying some of the 1.7tb worth of files :nashammer:
Message 3 of 8
mdgm-ntgr
Sounds like a disk issue, either with a disk in the NAS or the USB disk.
Can you send me your logs?: http://kb.netgear.com/app/answers/detail/a_id/21543/~/how-do-i-send-all-logs-to-a-readynas-forum-mod...
Message 4 of 8
2pods
I'm pressing the "download logs" button, but either nothing is happening, or they're being saved somewhere, but no idea where.
Message 5 of 8
mdgm-ntgr
It can take a little time for the logs to be generated. Though if it doesn't work you could try a different web browser.
Message 6 of 8
mdgm-ntgr
Are you able to connect the USB disk to your PC and test it?
Also are you able to power down the NAS, remove your disks (label order) and test them using SeaTools?
Message 7 of 8
2pods
Rebooted NAS both disks showing OK. Probably pilot error 🙂
I'll give the USB test a shot and report back
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1827 views
  • 0 kudos
  • 2 in conversation
Announcements
