Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas Duo V2 not booting (Filse system check, 100%)
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-30
07:44 AM
2013-12-30
07:44 AM
Hi,
I have some problem with my ReadyNAS Duo V2 boot.
It stays freeze during the system check (100%). I also try to skip the system check via boot menu but in this case the system freeze during the boot. The RAIDiator runs is the v5.3.8.
I have one hard drive installed (WD20earx 2TB) and I have alwais use it without any problem. The problem show after i have run a Backup task: All Media share (1,2TB of Data) copied to Frontal USB hard drive (2TB NTFS free). The task have run during the night and the next day everything is completed correctly. I eject the usb drive and shut down the NAS via RAIDar (v4.3.8). The next start the NAS doesn't start.
What can I do?! Please help me..
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-01
03:36 PM
2014-01-01
03:36 PM
Re: ReadyNas Duo V2 not booting (Filse system check, 100%)
I have done some other try. Maybe you can come to some idea...
1. With NAS hanged i try to check connected device to the router. I found the nas but its host name shown is UNKNOWN (usually it was my-nas)
a. try to access the nas via IP in windows explorer and I'am able to see all my data!
2. Insert a new Hard Disk and perform a factory reset and all work correctly.
3. Also I have read that a backup can generate a huge log file that can fill system partition. But without entering in Setup mode i cannot delete it.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-02
03:19 AM
2014-01-02
03:19 AM
You did a factory reset already? If so, the old log files have been deleted.
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-02
03:22 AM
2014-01-02
03:22 AM
A factory reset with a different disk installed instead it sounds like. So the problem disk should be untouched.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-02
04:01 AM
2014-01-02
04:01 AM
Yes, correct.
But how can i delete log file without repartiting the disk? OS Reinstall mode doesn't delete log file...
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-03
04:42 PM
2014-01-03
04:42 PM
My NAS is already UP thanks to mdgm!!!
Message 6 of 6
