Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas NV XRAID. Time for Expansion but a couple Questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-16
06:09 PM
2011-08-16
06:09 PM
I have a Readynas NV XRAID, so its definitely an "older" unit. It has 4x750GB drives. FIrmware version 4.14 [1.00a042]. Memory 256GB [2.5-3-3-7]
My questions are
1. I'd like to expand the drives capacity, but I don't want to have to format it to do so. I understand I can replace all 4 drives, 1 at a time, and after the 4th it will have a larger capacity, but I'm not sure of what version of firmware my unit was originally set with so I'm not sure if I can go beyond 750GB drives without wiping it first.
2. How will the unit perform with WD Caviar Green Drives. I would like them b/c my drives heat up as the unit is in a hot area but wanted feedback on them first.
3. My firmware is 4.1.4 but when I click on check for updates, nothing happens, and I read there was a 4.1.7 update out there. Any thoughts on this?
Thanks
My questions are
Thanks
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-16
06:16 PM
2011-08-16
06:16 PM
Re: ReadyNas NV XRAID. Time for Expansion but a couple Quest
You'll need to check the block size of your volume (see Why you might want to factory reset a Sparc ReadyNAS) . If you have the 4k block size you will need to do a factory reset
Pretty much any WD Caviar Green 2TB drive is going to be a 4k sector disk (if you don't do a factory reset after upgrading to 4.1.7 you will likely encounter poor write performance). Some of the lower capacity ones may be 4k sector disks as well.
Sounds like there may be a problem with your settings under Network > Global Settings in Frontview. You can manually install the update as described in the RAIDiator 4.1.7 Release Notes
I'd recommend having a read of What to do before expanding your ReadyNAS volume
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-18
05:09 AM
2011-08-18
05:09 AM
mikeap wrote: I have a Readynas NV XRAID, so its definitely an "older" unit. It has 4x750GB drives. FIrmware version 4.14 [1.00a042]. Memory 256GB [2.5-3-3-7]
Thanks
I have noticed this happens too, seems to be this only works if using IE as your browser.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-08-18
06:24 AM
2011-08-18
06:24 AM
You could have a compatibility issue (browser released after RAIDiator version you are running breaking compatibility) perhaps.
Message 4 of 4
