× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
ReadyNas NV+ expansion bigger drives
designvoid
Hi there,
I have a readynas nv+ and currently have 3 1TB seagate drives in it using xraid. I will shortly be adding a 4th drive, which is fine as I have done it before no problems. My question is tho, once I have all 4 bays filled I will naturally want to expand, my question is can I just replace one of the drives with a new 2TB drive and get the additional TB of storage or will it still treat it as a 1TB drive until I replace all the drives with 2TB drives?
Hope that makes sense! Thanks!!
Message 1 of 2
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNas NV+ expansion bigger drives
X-RAID on Sparc ReadyNAS e.g. your NV+ (v1) uses the capacity of the smallest disk. So you would need 4x2TB disks for vertical expansion. Of course you would replace one disk at a time and wait for the resync to complete before replacing the next disk. 2TB disks are the max capacity supported by your NAS.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1908 views
  • 0 kudos
  • 2 in conversation
Announcements
