- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas Pro 4 Unresponsive After Firmware Upgrade from 6.9.3 to 6.9.4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. I have an older ReadyNas Pro 4 (which I confirmed previously here) which I just updated from firmware version 6.9.3 to 6.9.4 hotfix 1. Since the upgrade the device will boot - the LCD shows boot up status messages, the correct firmware version (6.9.4) hostname and IP address - but is almost totally unresponsive after that.
When I try to access the web based admin interface, I'm prompted for a password and then I see the ReadyNas 6.9.4 splash screen, but the menu never loads. I can ping the IP address of the device. I can also browse shares via SMB, but it's painfully slow - it will take almost a full minute to list the contents of folders while I browse the file system in Window Explorer. Can someone help me with instructions for downgrading the firmware without having access to the admin interface? I'm worried that the firmware upgrae might have bricked my NAS. Thank you - any help is greatly appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNas Pro 4 Unresponsive After Firmware Upgrade from 6.9.3 to 6.9.4
Maybe first look at the status (and download the log zip file) using RAIDar 6.4. https://kb.netgear.com/20684/ReadyNAS-Downloads
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAIDar doesn't show any issues (see attached image). If I try to download the log files (which are only 2.1 MBs), it takes about 30 minutes to get to 3% and then just hangs indefinitely. No real help to be found on the Diagnositics screen either - it says "No Errors Found" under the System and Logs headings. If you have any other ideas they would be greatly appreciated. I'm willing to try anything at this point. Thanks for your time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have SSH access? Maybe go in and do a TOP command and see if some process is taking all the throughput. Even if a downgrade is the fix, it would be good to know the cause of the problem so it can be addressed. My Pro2 has no such issue, BTW.
AFAIK, it's safe top downgrade from 9.4 to 9.3, I believe I saw a moderator suggest that to fix issues later fixed by hotfix 1. You just have to do it locally.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I downgraded my rn526 from 6.9.4 back to 6.9.3 and had no problem.
