- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas RNDP6000 Array offline no disk failures.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Help! one of my 2 RDYNAS Pro 6 units (Both running OS6) locked up the other day with a kernal error from btfrs showing in the ui. I powered the unit down and after that the disk array now shows offline yet all disks show as healthy. When I login to the UI it shows two different 6 disk arrays one as Raid5 and says i need to delete that one to use the disks (DIsk 1,2,3,4,5,6) and the other it says unknown raid level but it will also let me remove that one if I wanted to. This was my backup destination nas however it has 500GB or so of downloads that I'd like to get off of it before I factory reset it. Can anyone help?
Thanks,
Kirk
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNas RNDP6000 Array offline no disk failures.
It appears to be a btrfs problem with journaling. Seems that when the kernal panic happened the unit kept writing data and som part of journeling continued to work but now I get a mismatch.
Here is what I see in the console when I try to mount the vol.
root@DATA:/# mount -t btrfs /dev/md127 /mnt/test
mount: wrong fs type, bad option, bad superblock on /dev/md127,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.
root@DATA:/# ^C
root@DATA:/# dmesg | tail
[ 45.076911] tx-checksum: enabled
[ 45.076913] rx-checksum: enabled
[ 45.076914] rx-polling: enabled
[ 45.134047] bond0: link status definitely up for interface eth0, 1000 Mbps full duplex
[ 45.134060] bond0: now running without any active interface!
[ 45.134230] IPv6: ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
[ 4671.714414] BTRFS info (device md126): has skinny extents
[ 4680.551073] BTRFS error (device md126): parent transid verify failed on 501495332864 wanted 25850 found 31092
[ 4680.564200] BTRFS error (device md126): parent transid verify failed on 501495332864 wanted 25850 found 31092
[ 4680.598032] BTRFS error (device md126): open_ctree failed
Thanks,
Kirk
