- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas Ultra 6 - 6.5.1 - Fan System speed below threshold
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Guys,
last night i upgraded my ultra 6 from 4.x.x to 6.5.1
correctly on the amin page I get a "The Fan is not working" notification.
I am sure this has probably been answered 1000 times before, btu I have read a few threads, and none of them seem to help me.
Can you guys please assist?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNas Ultra 6 - 6.5.1 - Fan System speed below threshold
Hi bakthomas,
Welcome to the community!
Can you clarify if you uploaded the 6.5.1 (RC) or the official 6.5.1 firmware? Also, prepare the device logs.
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ummmmm, I followed these people instructions.
https://community.netgear.com/t5/Using-your-ReadyNAS/Upgrading-from-4-2-x-direct-to-6-3-5-beta/td-p/...
So not sure which version.
Sorry.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sat Jun 25 2016 18:12:26
System: Fan System in enclosure Internal speed is below threshold. (0 rpm).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think both the PRO 6 abd Ultra 6 are experiencing the same issue with 6.5.1.
Going back to 6.5.0 was the solution for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello bakthomas,
You should be able to the see it in the admin page > Overview, it will say RC or Beta next to firmware version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware: 6.5.1 (Check for Updated)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello bakthomas,
That seems to be the official, then.
I haven't read OS6 NAS units users report this same problem. Like Supertramp11 suggested, revert to 6.5.0. If you are using an OS6 unit, I would suggest you to contact support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"I haven't read OS6 NAS units users report this same problem"
Except this user: https://community.netgear.com/t5/Using-your-ReadyNAS/Readynas-316-6-5-1-fan-threshold-below-speed/td...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue here... will try and downgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Today I upgraded my Ultra 6 (6x2TB) to OS 6.5.1.
I'm also having the reported fan error, however all fans seem to be working fine.
The overview only shows one fan: System.
CPU temp is 30 C / 86 F.
The system temp is 51 C / 124 F.
The fan shown in the overview seems to represent the largest fan.
When I look at the physical device the largest fan seems to increase the speed, immedeately slow down, increase again etc.
The speed of the fan shown in the overview is fluctuating between 0 and 1100-1200 rpm.
After downgrading to 6.5.0 there is stil one fan shown in the overview (shouldn't there be two fans shown?).
It has a stable speed 806 rpm.
The temperatures are the same as under 6.5.1.
The largest fan also seems to have a constant speed.
What I do not understand is why there is an rsync running to synchronise the data.
Shouldn't the data area be empty after upgrading to OS 6?
The data area isn't empty; it holds 35.56 MB of data.
The estimated time for the rsync is app. 17:00 (still 14:50 to go.
Is this normal behaviour?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Resync not rsync. The system is rebuilding the RAID array. On the data volume usage there will be a small amount of metadata. This is all normal behavior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're right. It is a resync.
Should there also be one fan shown?
- Mark as New
- Bookmark
- Subscribe
- Permalink
same issue here since I upgraded my ReadyNAS Ultra 6 to the latest firmware 6.5.1. Fan is jojoing up and down. Pretty anoying. A reboot and setting the fan speed to ballanced makes it a bit better when sitting close to it but after a shutdown the jojo is back on ballanced. Hope to see an update soon. Don't like the risks of downgrading or the need to backup 20TB of disks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS OS 6.5.2 is now available!
You could try
# echo 1000 > /etc/frontview/min_fan_speed_override
# systemctl restart readynasd
That should help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
my readynas doesn't see the update yet but setting the min_fan_speed_override helped. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 6.5.2 update is available for local updates only at this time.
I beleive there is a change coming in 6.6.0 that may help with this fan threshold issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have exactly the same problem after upgrading from 6.5.0 to 6.5.2 and am getting an email every hour re the fan speed being under the threshold however with over 2Tb of data to backup up I am loathe to go back to 6.5.0.
Is there likely to be a problem with letting it continue like this until 6.6?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be best to use the workaround I mentioned above or update to 6.6 RC2.
Letting the fan run into those errors is not recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have now connected this unit to an iMac (which has huge performance problems compared to Windows) running Sierra - do I use terminal to enter these commands?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The link to 6.6.0 RC2 is:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
All good, thanks Stephen (after I realised I had to enable SSH).
The fan speed continued to fluctuate for a few minutes after which time it has settled down at about 990rpm in Quiet mode with CPU @ 30C, System @ 43C and NO fan noise.
Really appreciate your help.
