Orbi WiFi 7 RBE973
Readynas 104 won't boot. Error 354 out_of_memory. After upgrade to 6.4.1 #26323717
Guru
Re: Readynas 104 won't boot. Error 354 out_of_memory. After upgrade to 6.4.1 #26323717
@corinbishop wrote:
However, like I said above, if something really thinks it will be better with a complete wipe/reset/restore then it's the one last thing I'll do.
A factory reset raised my speeds up to 70-75 MB/s on my RN102.  Though I never had 9 MB/s write speeds.
You can go back to 6.2.x, so if the reset doesn't cure it, you could try that.  It'd be a last resort, but it sounds like you are getting to that point.
Message 101 of 107
corinbishop
Guide
Thanks StephenB,
yes, I think I'm reaching the point of wipe/restore. I suppose I might as well. At this stage nothing too loose.
If do a wipe/restore how to I go back to 6.2.5? I've never done factory reset so not sure at what point it looks for firmware etc.
c
Message 102 of 107
Guru
You can do a factory reset from the web ui, or from the boot menu.  The web ui is more convenient.
The overall process is to
(a) uninstall apps
(b) save the config file
(c) back up data
(d) reset
(e) set up NAS again (just basic stuff)
(f) restore the config file
(g) restore the data
(h) reinstall apps.
In your case, perhaps stop after (e) and benchmark the performance.
I found a couple of glitches in the config file restore
-volume maintenance schedule was not restored
-backup jobs failed to run on schedule
For the second one, you can simply disable/re-enable the schedule for each job (if you run into it). I think the volume maintenance needs to be re-entered.
On downgrading: ifixidevices posted a procedure to downgrade that worked for him (and some others).  You need to install an old 6.4 beta as part of the process.  The link is here:
https://community.netgear.com/t5/ReadyNAS-Beta-Release/Downgrading-from-6-4-0-to-6-2-4-with-a-Pro-Pi...
Netgear doesn't recommend this.
Message 103 of 107
corinbishop
Guide
Thank you StephenB, I'm going to give it a go some time when I've got a few days spare to tend to it.
will report back
Message 104 of 107
mdgm-ntgr
NETGEAR Employee Retired
Any update?
Message 105 of 107
corinbishop
Guide
Hi.
I've not had time to do a wipe/restore.
Did find something strange today though. The write performance problem is only from Windows 7 machines.
I'm getting 6-8MB/s write, 36-40 read from my W7 machines. But I tried a Windows 10 machine there and I'm getting 40 both ways consistently.
odd... 6.2.5 worked fine. 6.4.2 slow from w7 machine.
Message 106 of 107
mdgm-ntgr
Split discussion off into a new thread as it was being dragged away from the initial topic.
For the original problem would advise backing up the data, doing a factory reset, configuring appropriate for use case and restoring from backup.
If not all the data can be backed up in volume read-only mode then we could have a remote look to see if disabling quotas allows the system to boot read/write to backup the reset.
Message 107 of 107
Top Contributors
Discussion stats
  • 106 replies
  • 7381 views
  • 7 kudos
  • 11 in conversation
Announcements
